Distributor buzz?? - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 19th, 01, 08:15 PM Thread Starter
With the turn signal on, engine off, I can hear my unilight modual intermitantly buzz as the signal flashes. I thought this was really strange so I figured I'd run it past you guys. My tach needle will also jump with the signal-I would assume they are related somehow. Any thoughts on this??
currently restoring my '67, 327, T-10,3.73 10 bolt
whitey is offline
post #2 of 3 (permalink) Old Sep 20th, 01, 06:43 PM
Joe
Just a voltage spike from the contacts in the flasher. The old points had a capictor which absord any spikes. Any time you have contacts open and close you get a small spike. Just dont use your turn signals with the car off and youll be fine. While the car is running the spikes get eaten up in the system so they pose no problems.
70 camaro 307 (350soon) /350th
Joekool1234567 is offline
post #3 of 3 (permalink) Old Sep 22nd, 01, 12:49 AM Thread Starter
OK, thanks for the insight. I was worried that there might be something wrong with the moddual in the distributor-I'ld have to replace it again
whitey is offline
