Oil pressure gauge - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 11th, 00, 09:56 AM Thread Starter
Lightbulb
I have a 67 rs 327. My oil pressure gauge has always shown the pressure to be right in the middle of the gauge. Yesterday the guage fell when I was at a stop. It went back to normal when I started moving again. I check the oil level and had to add just a little oil. Is this normal? or is the gauge screwed up?
goatjj is offline
post #2 of 5 (permalink) Old Dec 11th, 00, 10:06 AM
Sounds normal to me, your oil pressure will definitely drop at idle if you are a few quarts low on oil.......KZ
John D. Smith
69' SS/396
www.geocities.com/kz1000ltd
kz1000ltd is offline
post #3 of 5 (permalink) Old Dec 11th, 00, 10:14 AM Thread Starter
Thanx for the info kz. When I added oil it was about half a quart. Do you think there could be a bigger problem? I just don't want my baby to burn out.
goatjj is offline
post #4 of 5 (permalink) Old Dec 11th, 00, 01:59 PM
1/2 Qt low shouldn't bee too bad, Oil pressure is related to RPM. At idle, especially with hot oil the pressure can be low. Somewhere around 10-20 psi. Maybe a little lower. The actual minimum psi required can be debated. if it is sufficient to overcome the crakshaft "centrifugal force" and travel from the mains to the center of the crankshaft, then it is sufficient.
When you acclerate engine speed picks up and oil pressure it will rise.
TTFN
Mat
Mat Klemp is offline
post #5 of 5 (permalink) Old Dec 15th, 00, 05:43 AM
a good rule of thumb is 10psi for every K of RPM,
60psi = 6000
80psi = 8000
etc etc...
Chris's 67 RS can be seen at http://www.67rs.com
JOIN THE CAMARO NET WEBRING!
Chris Edwards is offline
