How do I rewire an ignition siwtch? - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 3rd, 01, 05:38 AM Thread Starter
Okay, I can now get the ignition switch off but I don't have the connector piece and the wires are not hooked up properly. This is the stock harness, it just that one of the previous owners must have of re-wired it. I have the 68 wiring diagram, but it doesn't help. It only shows a picture but doesn't tell me what color goes to which label (i.e. GRD, KEY+, KEY-, SOL...)
I drew a picture to reference, does anyone know where each wire goes?
Thanks!
Cars:
68 SS Camaro
73 Camaro -Daily Driver
Website:
http://68.dhs.org
[This message has been edited by ohayden (edited 08-03-2001).]
ohayden is offline
post #2 of 5 (permalink) Old Aug 3rd, 01, 07:20 AM
The best thing to do would be to go to a local junk yard and cut off that section of loom from a car with a similar switch. Get about 12 inches of wire plus the connector.
This may seem like a waste, but I'd bet it will save you a ton of time.
BTDT
Wes. Vann
Technical Reference Section
Wes V is offline
post #3 of 5 (permalink) Old Aug 3rd, 01, 07:31 AM Thread Starter
Exclamation
I would love to, but the bone yards around here really don't have any first gens in them. Any suggestions where I can buy one? Is the ignition harness sperate from the under-dash harness?
Cars:
68 SS Camaro
Website:
http://68.dhs.org
ohayden is offline
post #4 of 5 (permalink) Old Aug 3rd, 01, 02:19 PM
We'll try to work this out from the wiring diagram.
BAT Terminal - Red #12 to slice on Red wire to light switch.
ACC terminal - 2 wires #24 BROWN/White tracer and #12 BROWN to
SOL terminal - #12 PPL to neutral safety /clutch switch.
IGN Terminal - #12 PINK to bottom left fuse on fuse panel and thru bulkhead connector where it turns into the #20 W/B and Purple Resistor wire to the Ignition Coil
KEY (+) - #20 Pink Wire to Bulkhead connector where it turns into the 20 P,DBL/B wire and ends up on the Horn Relay
Key (-) - #20 Black Wire to 10 pin connector by emergency brake (Must tie into the door switch circuit at this connector)
This is the best guess I can make from looking at the wiring diagram.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #5 of 5 (permalink) Old Aug 4th, 01, 09:46 AM Thread Starter
Exclamation
Thanks Mark C!!!! You sure guessed it! You were missing one wire, but you had the exact order... The funny thing is, I still had the problem. I started tracing the wires and I found out there was a 12v red wire running to the pink wire with a black stripe. Looks like they were running an alarm off there. I pulled the wire and it all works! Hooray... I have not more electrical problems
I'll post the picture to help anyone else out. Here is the picture:
Once again, many thanks Mark C!!
Cars:
68 SS Camaro
Website:
http://68.dhs.org
ohayden is offline
