89' Camaro RS 2.8L Trouble Codes - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 23rd, 01, 09:45 AM Thread Starter
Hi Guys,
Can someone here please post a link to a list of what all the different trouble codes mean. I have a 89' RS 2.8L. The problem is I recently changed the distributor o'ring to fix an oil leak and now the check engine lite comes on after the car runs for about 15-20 minutes. I marked the distributor position before I took it out and the car seems to idle and run fine.
Thanks All,
89' Camaro RS 2.8L
roller is offline
post #2 of 2 (permalink) Old Jan 24th, 01, 05:59 AM
Lance
Go here: http://www.thirdgen.org/newdesign/faq/thirdgen.shtml
At the bottom of the page it tells you how to retrieve the codes and what they mean. Always the first step when a code appears is to disconnect the battery for 10 seconds to reset the computer. Run the car again and see if the codes reappears.
Spitfire44 is offline
