wiper motor hitting valve cover - Team Camaro Tech
post #1 of 19 (permalink) Old Mar 17th, 05, 01:16 PM Thread Starter
I have a 67 camaro and installed tall valve covers on the engine and now they hit the wiper motor. Does any one know of an easy fix.
junbug is offline
post #2 of 19 (permalink) Old Mar 18th, 05, 02:27 AM
shorter valve covers? this a big block or asmall block? y 327 has "fairly tall" alluminum valve covers, WITH a breather in that corner, and they cleared. yours must be huge!
post #3 of 19 (permalink) Old Mar 18th, 05, 02:35 AM
Harry
dawg's Avatar
i seen this happen to guys that use bigblock mounts on a smallblock before
434 stroker
US Navy retired
dawg is offline
post #4 of 19 (permalink) Old Mar 18th, 05, 02:47 AM Thread Starter
The valve covers I have are Edelbrock elite
and I have stock small block motor mounts.
I can't use the shorter valve cover because of the cam and roller rocker combo. They hit the shorter
valve covers.
junbug is offline
post #5 of 19 (permalink) Old Mar 18th, 05, 03:55 AM
something don't make sense then... can you post a pic?
post #6 of 19 (permalink) Old Mar 18th, 05, 11:04 AM Thread Starter
Do you have the measurment of the small block mounts.
junbug is offline
post #7 of 19 (permalink) Old Mar 18th, 05, 11:28 AM Thread Starter
Here is a link. Maybe I'm doing somthing wrong?
http://hobbystage.net/camaro/junebug40/
junbug is offline
post #8 of 19 (permalink) Old Mar 18th, 05, 11:45 AM
Jack
I also have tall covers and I do need to remove the wiper motor to remove the cover. Your covers seem to be a 1/2 in. or so taller than mine. That would be enough to remove any clearance there was.
67 RS
Royal Plum/Parchment
6.0 LSX 4L80e
06 corvette Z06
machine silver
jackr is offline
post #9 of 19 (permalink) Old Mar 20th, 05, 09:20 AM
www.detroitspeed.com
selecta speed wiper motor, will clear most applications
its a $300 fix, lol which may not be so easy for some, but its an option
aonghus is offline
post #10 of 19 (permalink) Old Mar 20th, 05, 09:29 AM
I had problem with the valve covers hitting the valve train componets. Found out my Valve Covers where on the wrong side; had passenger side on drivers side and visa versa. I did not know they were side specific. They were slightly angled. swaped side problem gone.
How are you phasing your wiper motor. I have seen them installed wrong and interfer with valve covers.
Also are you using the one-piece reuseable style mr gasket or felpro gaskets (around $29 a pair) cant think of better way to describe them. I am not sure of part numbers but some add about a 1/4-inch height to covers even when cranked down on.
just my 0.02
WillS is offline
post #11 of 19 (permalink) Old Mar 20th, 05, 10:51 AM
Harry
dawg's Avatar
man your motor is really high in the pics?
are you positive you have the correct engine mounts in there?(engine crossmember mount aswell)
I have tall valve covers on my car and got at least 1 to 2 inches of clearance there?
heres a pic:
http://webpages.charter.net/harrycoo...%20of%20engine
434 stroker
US Navy retired
dawg is offline
post #12 of 19 (permalink) Old Mar 20th, 05, 01:37 PM Thread Starter
Yes I beleive I am. If you look at my web page I toke a pic. of the manual and I'm installing it just like that.
As for the gasket I am using a Mr Gasket Ultra seal
part # 5861 and it to is about a 1/4" thick.
junbug is offline
post #13 of 19 (permalink) Old Mar 20th, 05, 01:39 PM Thread Starter
The clearce between the oil pan to cross member is only about 1" I don't think it can get any closer then that but I could be wrong ?
junbug is offline
post #14 of 19 (permalink) Old Mar 20th, 05, 01:42 PM Thread Starter
Yes I live real close to where detroit speed use to be and I seen them at the camaro super fest.
That wiper motor loos like the one in my pick !
junbug is offline
post #15 of 19 (permalink) Old Mar 20th, 05, 02:20 PM
Robert
jackr is correct. I've had tall covers on the '67 when using roller rockers and had to loosen the wiper motor to get the cover off. The Edel' Elites have always appeared to be taller, not sure how much but that would explain your problem.
Robert
TC member #18
rojo is offline
