Ever look into converting to all LEDís? - Team Camaro Tech
 2Likes
  • 1 Post By imbucky
  • 1 Post By ilikeike
post #1 of 6 (permalink) Old Jun 14th, 17, 02:24 PM Thread Starter
Bucky
Cool Ever look into converting to all LEDís?
Well, Iím gonna save yousome time and hopefully some money too!
I looked through a bunchof manufacturers and kept finding myself at superbrightleds.com. Their websiteand search tools seemed the best for what I was trying to do for my 1967 CamaroRS convertible.
You can look at theconversion and Sylvania or Osram bulb guide too but there are still holes indoing so. I contacted this company to let them know what bulbs works and what didnít.
Here is what I found, thebulb numbers are for the Superbrightleds.com;
Ashtray bulb-BA9S
Clock-gauges-consolelights-(4)BA9S
License-BA15S
Trunk- BA15S
Rear seat courtesy-578
Under dash courtesy lights-67-W15(2) (do not get BA15S, they are too long, wont work)
Reverse-1156
Front running-1157A Amberlight. Will not work, the solder it too long, doesnít fit in fixture.
Glove box-BA9S
Instrument DashCluster-194-WWHP5 (6)
I didnít use the led bulbsfor the tail lights but rather a Dakota Digital kit instead, just based onreviews.
This is what I ordered andI have the whole car converted except for the running lights. The searchcontinuesÖÖ
robbys67rs likes this.
1967 RS Convert. numbers matching 327/275 with 4 speed hurst on top of a saginaw, 12 bolt 355 rear end, console w/gauges & deluxe int., ORIGINAL PLUM!
Let's Roll!!
imbucky is offline
post #2 of 6 (permalink) Old Jun 14th, 17, 03:26 PM
Darin
ilikeike's Avatar
Re: Ever look into converting to all LEDís?
I had to grind the base of the 1157 superbrightled replacements at the base where the solder is to get them to fit properly,only took a second. and then I used the Dakota no load flashers. I did the front turn/parking,side markers and rear brakes/turn, under dash,rear console and dome, works great.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #3 of 6 (permalink) Old Jun 15th, 17, 06:30 AM
boyd
where do you get the Dakota no load flasher?
boyd66k20 is offline
post #4 of 6 (permalink) Old Jun 15th, 17, 06:33 AM
Vega$69's Avatar
3 second google search
https://www.summitracing.com/search/...ignal-flashers
Vega$69 is offline
post #5 of 6 (permalink) Old Jun 15th, 17, 09:41 AM
Chris
130fe's Avatar
Cool Re: Ever look into converting to all LEDís?
I have used this flasher with success, price is good also.
I converted to all LEDs in my 68. Used Trucklite headlights, digi-tail tail and front marker and the rest purchased off of eBay. No issues at all.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #6 of 6 (permalink) Old Jun 15th, 17, 12:05 PM
Darin
ilikeike's Avatar
Thats actually what mine looks like when you peel the Dakota sticker off.
130fe likes this.
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
Tags
interior lights, led lights, light bulbs
