1969 Camaro wiring - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 15th, 03, 12:31 PM Thread Starter
madmax87's Avatar
I'm building a 69 Camaro from the ground up. I'm installing the engine harness and I'm using a 1 wire alt. I know how to wire the alt up but how do I get pwr to the fuse box. I'm not using a horn relay or a voltage reg. Do I just run a line from the terminal block on the rad core to the fuse box? I using a new stock engine wire harness that has all the connections for a normal setup.
madmax87 is offline
post #2 of 3 (permalink) Old Jan 16th, 03, 01:31 AM
That would work fine.
Or tie together all the red wires, that is the terminal lugs of those attaching to the missing components.
Everett "OBJECTS IN THE MIRROR APPEAR QUICKLY UPON RAPID DECELERATION"
[This message has been edited by Everett#2390 (edited 01-16-2003).]
post #3 of 3 (permalink) Old Jan 17th, 03, 12:10 AM Thread Starter
madmax87's Avatar
I was told to tie the blue and brown wires together that were originally on the voltage regulator. Does that sound right? Also, did the horn relay supply the 12v to the fuse panel?
<BLOCKQUOTE>quote:</font><HR>Originally posted by Everett#2390:
<HR></BLOCKQUOTE>
madmax87 is offline
