68 camaro turn signal problem - Team Camaro Tech
 2Likes
  • 1 Post By 69-Pace
  • 1 Post By DOUG G
post #1 of 7 (permalink) Old Jun 19th, 17, 02:02 PM
Camaro572
Guest
Posts: n/a
When I turn on the lights on my 68 camaro the left turn signal comes on.
The light doesn't blink but comes on permanent.
When I try to blink to the left signal nothing happens.
The light still just stay of and doesn't blink.
When I blink to the right everything is ok.
Last edited by 69-Pace; Jun 19th, 17 at 05:34 PM. Reason: I edited for clarity - translation from Norge was too rough. :)
post #2 of 7 (permalink) Old Jun 19th, 17, 05:37 PM
69-Pace's Avatar
Re: 68 camaro turn signal problem
Biorge - Velkommen!
So if I follow you right you get constant BRIGHT light in the left turn signal as if it was stuck in a flash.
Does it continue to remain bright with a head lights on also?
Do you get the left to flash if you turn on the 4-way emergency flashers (hazards lights)?
ZZ_430 likes this.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 7 (permalink) Old Jun 19th, 17, 06:17 PM
Sounds like maybe a ground issue. Double check and/or add a ground to verify.
1968RallySport likes this.
68 Camaro~LSx ~all motor
post #4 of 7 (permalink) Old Jun 19th, 17, 08:02 PM
Chick
68camaroz28's Avatar
X2 on ground issue. Adding a ground to verify is quick and easy to verify & I'd bet that is the issue.....
Chick
68, 69, & 2015 Z/28's
69 Nova's L34 Father/Son & L78 Surv purch-new
67, 68, & 2015 Z06 Corvettes
Our 68Z Restoration
68camaroz28 is offline
post #5 of 7 (permalink) Old Jun 25th, 17, 02:46 PM
Larry
X3 on the ground, specifically the left parking light housing. Without a ground current from the parking light circuit flows through both filaments and back up to the turn signal indicator.
Current Project:
69 Z/28 Resto-Mod
Next In Line:
83 Z28 Restoration
69-er is offline
post #6 of 7 (permalink) Old Jun 30th, 17, 04:14 AM
Camaro572
Guest
Posts: n/a
Found it. Wire off in the front left turnlight and a wrong bulb in the rear
post #7 of 7 (permalink) Old Jun 30th, 17, 08:09 AM
Kudos in finding the problem.
