Wiring for Back-Up Lights? - Team Camaro Tech
post #1 of 9 (permalink) Old Jun 22nd, 17, 09:23 AM Thread Starter
My car doesn't currently have _working_ back-up lights, or a switch in place. So I bought a new Hurst switch for the trans (Super T-10), and was wondering where I might find the correct wire connector under the dash? Is it color coded or does it tap into the orange and white wire for the console light for power? I'm going to guess that wire from the switch is going to run through the tunnel but under the console or carpet up to the dash and then link up with the fuse block?
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is offline
post #2 of 9 (permalink) Old Jun 22nd, 17, 10:01 AM
Re: Wiring for Back-Up Lights?
What year make and model car are you dealing with for this ?.
Is the wiring original in the car or is it a replacement harness or a custom made one ?.
SOA-Nova is offline
post #3 of 9 (permalink) Old Jun 22nd, 17, 10:51 AM
Vega$69's Avatar
You just need Keyon 12v to one side of the switch and wire other side the BU light
Vega$69 is offline
post #4 of 9 (permalink) Old Jun 22nd, 17, 11:33 AM
69-Pace's Avatar
Mike - Not sure if your 69 still has the reverse lock-out rod in place from transmission to bellcrank on the firewall but that rod controls the reverse switch as the rod turns the sleeve on the steering column from the firewall.
So in any event if it is in place or not you can tap and extend the original wiring. However since 69's required the car to be in reverse to get the key out I would suspect that the switch has been engaged forever (especially if you have been able to remove the key without putting her in reverse or turning the sleeve by hand on the steering column.) that your backup lights do work but the bulbs are just dead.
Most folks who removed the rod from the transmission forward to the bell crank just rotated the sleeve into the reverse position to get the key and either manually rotated it to turn off the lights while driving, or never cared and left them on, or liked to send the signal "lets race" at every traffic light.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #5 of 9 (permalink) Old Jun 22nd, 17, 07:10 PM Thread Starter
Jim... its a '69 Camaro.
Brian... Car is on the lift at Road Runner right now so I can't check... but I'm pretty sure the linkage you're talking about is long gone. IIRC, at the column as it exits the firewall there's a lever that appears to be wired in a locked position.
There's no wire anywhere near the trans so I'm assuming that in the restoration process and conversion from an automatic car to a stick car... the BU lights were forgotten. Once I dig around under the dash, I'll probably find something running from the fuse block or harness. Thats why I asked about whether there was a color code wire I should be looking for.
Figuring the tail lights are all working and grounded, so also going to check the BU sockets to see what wires are coming out of there. Needless to say, as John said... just need keyed-on power to go to the switch, then back to the light harness. Its not a big deal, but just another of those little things you'd like to get working.
If the Gods smile on me tomorrow, I'll hopefully go pick her up. Major front-end steering, brakes, suspension upgrades should put a smile on my face.
57vette is offline
post #6 of 9 (permalink) Old Jun 22nd, 17, 07:25 PM
The wires for the back-up light switch are pink and green. You should find them under the dash and they are routed differently from there depending on the shifter configuration.
Old Dad's 67 is offline
post #7 of 9 (permalink) Old Jun 23rd, 17, 05:02 AM
Brent
67Rally's Avatar
I have some info in post #68, 69 & 72 of my build thread. It's on a '67 but may apply to yours as well, at least give you some pics...
https://www.camaros.net/forums/56-pro...ml#post1519224
67Rally is offline
post #8 of 9 (permalink) Old Jun 23rd, 17, 07:26 AM
I did an auto to 4-speed conversion. On an auto car, the pink and green wires run to shifter neutral safety switch through the console. I drilled a hole through the tunnel next to the shifter cut-out and ran the wires to the back-up switch through a grommet.
post #9 of 9 (permalink) Old Jun 23rd, 17, 07:50 AM
69-Pace's Avatar
As in Muffler?
69-Pace is offline
