Dumb question maybe.... - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 21st, 03, 02:35 PM Thread Starter
I have a black box on my inner fender, drv side approx 2 inches cubed with 4 connectors at the bottom front at the bottom edge, only one wire ( a heavier guage red one) is hooked up, I cannot find refrence to this anywhere, anyone know what it is? The car is a 67 RS/SS...Thanks
[This message has been edited by sherr20 (edited 01-21-2003).]
sherr20 is offline
post #2 of 7 (permalink) Old Jan 21st, 03, 03:10 PM Thread Starter
Ok, upon further inspection, it looks just about identical to the volt. regulator, but only has one wire which comes out of pin 4 and then ties into the wire from the atenator and the double spade mount on the horn relay, this little "homemade looking splice also ties in pin 3 from the real voltage regulator front light harness. So this is the question, it seems to me this "add on" is not necessary, is that right? My front light wire harness is a mess, I have a new one but am trying to figure out what everything is and what should be there and what shouldn't.
Oh, also wired into this bundle is a wire with an inline fuse that goes to one of the headlight relays....again rigged...thinking to bypass the CB, which I cannot find.....
I have the classic ind. rs dash headlamp and console book, but I am not matching my new harness to the diagram very well, colors seem to be off some, also comparing to current harness. Anyone have this problem before? Maybe somthing in more laymens terms....3 pin plug with 2 blues and a black here or somthing like that?
Thanks..
sherr20 is offline
post #3 of 7 (permalink) Old Jan 21st, 03, 03:43 PM
It's your horn relay. The red wire runs over to a terminal block on te firewall in front of the battery. The other side of the terminal goes to the positive terminal on the battery. This wire is the main power connection for the whole car, and the charging lead from the alternator to the battery. It has a black and a black and white wire that goes to the horn buttons in the steering column, and a green wire to the horns. The terminal with the red wire is the main power feed to everything in the car. It is spliced to the output wire from the alternator in the wire bundle about 8 inches from the horn relay.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
My 69 L48 - 350/300HP Engine
Mark C is offline
post #4 of 7 (permalink) Old Jan 21st, 03, 03:53 PM Thread Starter
Thanks for the reply Mark, but I see my horn relay under my voltage regulator on the bac side of the radiator support, this box is on the drv inner fender well above the upper control arm, it looks just like the voltage regulator....identical, without the condensor looking cylinder next to it....i'm thinking past owners messed up....??? any ideas? I'm going to put in my new harness, it just threw a loop in the equation.....do you have an email I can send a pic of it I just took.
Jerry
sherr20 is offline
post #5 of 7 (permalink) Old Jan 22nd, 03, 03:52 AM
It's in my profile above each post, the icon that looks like an envelope. By the way if anyone else sent me mail recently and I didn't get back to you, I had an email meltdown yesterday and lost all my mail, and addresses. So if I own anyone a response for something please send it again.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #6 of 7 (permalink) Old Jan 22nd, 03, 01:25 PM
click's Avatar
Mark I think I recall you owe me $2,000 for a used Carb Ujoint I sent you
.... Click aka Jim .. Cylinder Index = 31
Dover White 69RS 350/255 LM1, TH-350 auto., A/C
Blue Vinyl top, F&R spoilers, 3.08 Eaton Posi.
fold down rear seat, PDB, PS, Cowl Induction, Endura Bumper
My RS.. www.brainerd.net/~knudsen/69RS
click is offline
post #7 of 7 (permalink) Old Jan 22nd, 03, 04:49 PM
Guess
HwyStarJoe's Avatar
LOL!!!!
HwyStarJoe is offline
