67 Camaro bbc Engine harness - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 20th, 01, 12:42 AM Thread Starter
Having trouble identifying some wires on my new engine harness, the longest is orange with female spade & rubber boot. Then there are 2 together, one purple & one slightly smaller gauge yellow , both with eye terminals. I have'nt been able to find a good schematic with color codes, thanks, Mike.
Mike Anderson is offline
post #2 of 5 (permalink) Old Mar 20th, 01, 03:20 AM
The purple and yellow ones sound like they go to your starter. The yellow one should run from the solenoid to the distributor, it provides 12 volts to the coil during starting, bypassing the coil resistor wire. The purple is the one that picks up the solenoid from the key switch.
Only wires I can think of that have female spade style terminals on it in the engine compartment is for the oil pressure idiot light, or the brake warning light on the proportioning valve. The brake one is a round terminal though, the oil pressure switch is a flat spade terminal.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #3 of 5 (permalink) Old Mar 20th, 01, 04:36 PM
Procurement_man's Avatar
Thumbs up
Orange wire on my 67 is for the heater blower / fan. Yellow and Purple go to starter. Hope this helps.
Procurement_man is offline
post #4 of 5 (permalink) Old Mar 20th, 01, 05:33 PM
Carl
The purple wire will go on the inboard terminal of the solenoid, the yellow on the outboard.
Pro-man is correct on the orange wire.
Click here to see see my car and hear 5-speeds. http://www.geocities.com/casanoc
CarlC is offline
post #5 of 5 (permalink) Old Mar 22nd, 01, 04:37 PM
scott67ss396's Avatar
ya the orange is for the blower just looked at my car to make sure they are all wright good luck
scott67ss396 is offline
