67 In-dash Tach Wiring - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 23rd, 01, 06:36 PM Thread Starter
I have a factory tach that I just got back after having it rebuilt. I think it was fried due to improper wiring by the previous owner. What color is the wire that runs to the negative side of the coil. It was hooked up with a yellow wire, but I think it is wrong. There is a brown wire coming off of the firewall that is cut. I don't want to fry another $130.00.
http://geocities.com/mike67rs/1.html
[This message has been edited by Mike67RS (edited 01-24-2001).]
Mike67RS is offline
post #2 of 6 (permalink) Old Jan 24th, 01, 01:07 AM
Bruno
My 68 has a brown wire coming out of the fuse block that goes to the parking brake pedal assembly to activate the brake light in the dash.I also want to know which wire goes to the tach. in case I can send mine for repair.Good luck.
ORENCH is offline
post #3 of 6 (permalink) Old Jan 24th, 01, 11:06 AM Thread Starter
I figured it out. The tach neg. lead is dark brown. It is in the #1 position on the plug that connects to the back of the guage panel. (To the circuit board) The wire which runs to the neg coil is brown as well. Now, if I can just figure out what the yellow does that comes off the firewall.
Mike67RS is offline
post #4 of 6 (permalink) Old Jan 24th, 01, 08:07 PM
The yellow wires under the dash go to either the radio or glove box light (positive) or the heater switch. Under hood side of firewall a aprox. 12 ga wire goes to the blower motor.
Geezer
Geezer is offline
post #5 of 6 (permalink) Old Jan 25th, 01, 06:21 PM
David Pozzi
davidpozzi's Avatar
There is a yellow wire that goes to the starter. It's the starter bypass that bypasses the resistance wire in the harness for starting. It goes to the coil + terminal.
You don't need this wire if you have electronic ign.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #6 of 6 (permalink) Old Jan 25th, 01, 08:06 PM Thread Starter
Thanks David, I think that is it. I have noticed no problems with it disconnected. What does it do?
Mike67RS is offline
