subwoofer installation in 1993 camaro - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 18th, 01, 05:15 PM Thread Starter
Lightbulb
I have recently recieved a subwoofer assembly from what i believe to be another 1993 chevy camaro, It sits in the rear gully area of the trunk, it has a panel to go along with it that is imprinted with the delco/remy tag. the problem is the rest of the wiring harness is still in the other car but i can not get it out do the accident the car was in the drivers door is salmmed shut. The subwwofer has five wires coming into it and then on the inside of the casing it has what i believe to be a small pre-amplifier. What the question is; is does anyone know how to wire it to my radio and what each wire is for.The two wires that go to the speaker itself are red and green the others are what i believe to be orang,violet,white,black and,brown. I have replaced the orig. stereo with a jensen cd-player but if someon could tell me what the wires are i do kow how to wire it in. I have been told that the speaker is actually mad by bose. any help appreciated thaks
mikef is offline
post #2 of 3 (permalink) Old Sep 19th, 01, 08:07 AM
Steven
Some dealerships "farm" out stereo and aftermarket accessory work to local specialty stores. Call you local Chevy dealer and ask them who does their stereo work. If it is indeed a local shop, stop by and ask them a couple of questions. The may also be able to provide a harness. If not, look up www.crutchfield.com ... get their tech number and give them a call ... Crutchfield carries a lot of stuff and may be able to help also...
sdtsdt
sdtsdt is offline
post #3 of 3 (permalink) Old Sep 21st, 01, 07:36 AM
Do you know who is the manufacturer of the setup? Is it a factory setup or an aftermarket setup? Are there any model numbers? Is the amplifier mounted to the sub box setup? Let up know and it should be able to be installed, even on an aftermarket deck.
gm4life is offline
