A/C wiring harness - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 7th, 05, 08:20 AM Thread Starter
I'm installing the missing A/C wiring harness in my 69 car with a SB.
I'v figured most of it out, with a few exceptions.
Engine side:
1) The fuse wire, has a connection which looks like it goes to the main fuse box for power, what location in the box does it go?
2) The harness wraps around the evaporator core box, one plug goes into the side of the box between it and the fender, then there are two more single wires. Do these go to the blower motor?
Inside of car:
1) One connector under the dash of the car goes to the top of the heater box, I see were it goes. Does it matter which way it goes on? Or will it only go on one way? (i.e, there are two colored wires to the connector, does it matter which wire touches which prong).
THANKS for any help
HO69 is offline
post #2 of 7 (permalink) Old Mar 7th, 05, 02:41 PM
Charles
the in-line fuse wire is orange on the a/c harness and changes (at the in-line fuse) to a black 10 ga. wire that goes to the batt. terminal on the horn relay, not the fuse box.
two wires to the blower motor...yes. there is a ground tab bolted to the fan motor housing for the second wire, it is located on the fan mounting bolt right next to the blower motor terminal. 12 ga. purple to blower, 12 ga. black to ground tab.
connector underdash...2 tan wires on one side and light green on the other terminal. could probably be put on either way since it's switch controlled, but the wiring manual shows the l. green wire towards the firewall. but again i don't think it matters.
BELIEVE IN YOUR DREAMS
1969 SS X55 NOR added RS all NOS sheetmetal, ground up resto. 24 year project and dream. optioned out the wazoo. in one thousand pieces, and coming together finally.
Run269 is offline
post #3 of 7 (permalink) Old Mar 8th, 05, 03:06 AM Thread Starter
Hey thanks a lot for the information.
Especially the fuse wire. I have the black part of the wire and for some reason I was thinking the connection on the end was the type that goes to the fuse box, but I now see its not that type. I will be able to finish up my connections tonight. I guess I'm going to have to remove my fender to get at the blower motor, really hate to do that.
THANKS AGAIN!
HO69 is offline
post #4 of 7 (permalink) Old Mar 10th, 05, 03:09 AM Thread Starter
RUN269,
I have another question on the A/C harness. I'v removed my fender to hook up the last two wires. There is already a wire attached to one of the prongs on the blower motor. I think I seen somewhere in one of the diagrams something with the radio, but not sure, what do I do? Do I disconnect the one there? If I do, what do I do with it?
THANKS!
HO69 is offline
post #5 of 7 (permalink) Old Mar 10th, 05, 08:01 AM
click's Avatar
The blower has one push on wire with a rubber boot and the other wire grounds to the motor frame itself. Ive seen a diagram of a capacitor for radio suspression also in that area but mine doest have it. Im on the road and not home to check but thats what I recall.
click is offline
post #6 of 7 (permalink) Old Mar 10th, 05, 05:04 PM
Charles
option U63 A5 page 439 in the 69' AIM shows the radio capacitor.
if you have a capacitor just plug the blower feed into it. the capacitor bolts to the right front bolt on the cowl plenum valve bracket. (that thingy with the door in the cowl vent area below the windshield and above the A/C suitcase).
does this sound like what you have HO69??
Run269 is offline
post #7 of 7 (permalink) Old Mar 12th, 05, 10:21 AM Thread Starter
Well, thats what I thought too and I seen in the diagrams to connect in between the radio wire, but I dont have the capacitor. I do have an orange wire coming off the blower but does not go to a capacitor it runs across in a wiring harnes. So I figure I will either disconnect the orange wire and leave hanging, or maybe spice the A/C wire into the orange wire, or if I can get that capaitor sl=plice it in.
HO69 is offline
