brake light - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 14th, 00, 05:58 PM Thread Starter
when i turn the key on the light for the brake light from the dash comes on, the brakes were recently bled and the light didnt come on before that. do i have a elevtrical prob or a fluid prob. please help
zac braaksma is offline
post #2 of 6 (permalink) Old Dec 15th, 00, 01:45 AM
Johnny
Does it stay on all of the time or go off after a few seconds?
johnny
johnnyr is offline
post #3 of 6 (permalink) Old Dec 15th, 00, 06:41 AM
the equilibrium is messed up, you drained air out on one side or one side still has some air in it. re bleed them , it should clear out.
Chris's 67 RS can be seen at http://www.67rs.com
JOIN THE CAMARO NET WEBRING! http://nav.webring.yahoo.com/hub?ring=camaronet&list
[This message has been edited by Chris Edwards (edited 12-15-2000).]
Chris Edwards is offline
post #4 of 6 (permalink) Old Dec 15th, 00, 10:54 AM Thread Starter
i will try to bleed the brakes soon, and yes the light stays on whenever key is in/or car is started
post #5 of 6 (permalink) Old Dec 15th, 00, 09:12 PM
also check switch on emergency brake pedal, you may have bumped it during bleeding process.
69 rallye green X77 Z/28,1967 SS 396 Conv. 1974 c-10 454 swb
pipeman is offline
post #6 of 6 (permalink) Old Dec 16th, 00, 03:36 PM
JohnZ's Avatar
If the light comes on without stepping on the brake pedal, it has nothing to do with the hydraulic system - you have another problem, most likely the parking brake warning switch. The switch inside the combination valve only grounds when there is a difference between front and rear system brake fluid pressure, and that only happens when you step on the brakes.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
