Getting light from 68 AM radio - Team Camaro Tech
 4Likes
post #1 of 17 (permalink) Old Jun 28th, 17, 07:52 PM Thread Starter
Craig
So I just bought a 68 AM radio for the dash in my camaro. It is a filler only and not going to be used but I would like the light to illuminate when the headlights are on. Does anyone have a write up or a link to a bulb and socket set that I can use for this to replace the old one? Thanks
1968 454 TH350 Red with Black vinyl top
cmking26 is offline
post #2 of 17 (permalink) Old Jun 28th, 17, 07:57 PM
Steven
stamatisg1977's Avatar
Just wire it up as if u were going to use it but dont hook speakers up to it and keep volume down or off
stamatisg1977 is offline
post #3 of 17 (permalink) Old Jun 28th, 17, 08:20 PM
69-Pace's Avatar
Re: Getting light from 68 AM radio
Jeeze didn't you buy it yesterday? Thats fast shipping.
The light bulb can be replaced with LED, and you can use the full radio harness which includes a wire for illumination from the dimmer circuit (gray wire maybe?) Or just connect the gray up. Or hook your own harness lead to the light to the Instrument dimmer spade in the fuse panel to have the dimmer control the light.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 17 (permalink) Old Jun 29th, 17, 07:36 PM Thread Starter
Craig
So if I connect the wire on the bulb to the dimmer switch circuit do I then have to ground the radio? There's no ground from the light bulb socket.
cmking26 is offline
post #5 of 17 (permalink) Old Jun 29th, 17, 08:19 PM
69-Pace's Avatar
Yes once the radio is installed the metal strap bracket on the unit completes the ground.
69-Pace is offline
post #6 of 17 (permalink) Old Jun 30th, 17, 08:11 AM
I believe the gray wire in the connector is dash light power.
So radio dial light should vary with dash lights as HEADLAMP switch is turned.
post #7 of 17 (permalink) Old Jun 30th, 17, 08:24 AM Thread Starter
Craig
I'll have to find one of those radio straps (bracket) I'm missing that.
cmking26 is offline
post #8 of 17 (permalink) Old Jun 30th, 17, 10:14 AM
You can use a length of perforated strap as it would go from top of dash bracketry to pass side of radio at rear, U-nut should be there.
Radio power is a black w/yellow stripe and apparently dail light comes on with power applied from ign switch, my mistake.
69-Pace likes this.
post #9 of 17 (permalink) Old Jun 30th, 17, 03:23 PM
69-Pace's Avatar
Worth a look at your existing hanging harness. All cars came with them either used or taped up under the dash. They all included the dimmer instrumentation fed wiring.
So unless over the years someone installed an "over the counter aftermarket" radio and cut the plug off, but still gray lead should still be hanging and can easily be connected to the radio connector with a standard connector at any auto parts store. Sanyo's of the day used the gray light to blend in, Kenwood and Pioneer units of the made late 80's early 90's also had the ability to use dash instrumentation even when the radio was powered off.
69-Pace is offline
post #10 of 17 (permalink) Old Jul 1st, 17, 03:47 PM Thread Starter
Craig
I ordered the new pigtails, if I find the grey dimmer wire behind radio I'll just splice into it and then just ground under the dash somewhere.
69-Pace likes this.
cmking26 is offline
post #11 of 17 (permalink) Old Jul 17th, 17, 03:29 AM Thread Starter
Craig
Thank you guys, the pigtails worked perfectly and now my heater control and am radio light up with the headlights.
69-Pace likes this.
cmking26 is offline
post #12 of 17 (permalink) Old Jul 17th, 17, 04:54 AM
Thank you for the fix.
post #13 of 17 (permalink) Old Jul 17th, 17, 07:34 AM
Glad you got it going.
Were you able to find a gray wire behind the dash or did you wire into the fuse block ?.
SOA-Nova is offline
post #14 of 17 (permalink) Old Jul 17th, 17, 02:38 PM Thread Starter
Craig
There was a grey wire there, but I already had some gauges wired for light so I just taped into that instead.
cmking26 is offline
