Turn signal cam bad? - Team Camaro Tech
post #1 of 1 (permalink) Old Feb 27th, 05, 07:11 AM Thread Starter
Ok, about 6 months ago I pulled my wheel down and replaced the turn signal cam.. I have been fighting with brake light and hazards for a while now because they have been failing intermiditally. Yesterday I pulled the wheel apart and was able to recreate the problem. I'm going to do my best to describe this so hang in there.. You have the cam turn switch and something it snaps into.. (not sure what its called) Anyway when I pull the top left section where the lever screws in of the switch away (oppistite the brass piece where the springs are) I have all lights again.. As soon as I snap it back into place where it belongs I lose the lights.. Not sure whats going on because It looks to me lights its all plastic.. As a test I made a spacer (ok it was a piece of cardboard ) to go between the cam switch and ?? and re-assembled, drove it for about an hour and had no problems.. Does anyone know why snapping the switch in properly will cause this? I'm thinking the switch is bad. Hope I explained this ok.
Thanks in advace, Joe..
1969 Coupe - 427, TH350, 12 bolt, Eaton Posi w\3:55 gears.. <br /><br />It's a love\hate relationship!!
69427 is offline
