Sunpro Oil Pressure Guage Hookup - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 28th, 02, 04:21 AM Thread Starter
I bought an aftermarket set of guages to mount under the dash. They are the Sunpro 3 pod guage cluster with oil pressure, water temp and volts. I have the temp and volts hooked up but here's my question. I've heard horror stories about the plastic hose that's used to connect the oil pressure guage to the engine breaking and causing oil to leak into the interior or engine compartment. How big of a concern would this be and do any of you have other methods of connecting this guage (steel or copper lines)? Maybe I'm just being over cautious, but any input would be greatly appreciated. Thanks! Bill
redlines4us is offline
post #2 of 5 (permalink) Old Dec 28th, 02, 04:41 AM
Going to a metal tube is a good idea.
One can go to a refrigeration parts place or a hydraulic hose retailer and pick up either 1/8 inch copper tubing or steel tubing. Copper tubing has a much smaller ID than steel causing the gauge to react very slow.
Summit does sell an oil line kit of stainless steel braided tubing in three lengths, 3', 4', 6'.
Everett "OBJECTS IN THE MIRROR APPEAR QUICKLY UPON RAPID DECELERATION"
post #3 of 5 (permalink) Old Dec 29th, 02, 06:26 AM
JohnZ's Avatar
Copper tubing isn't a good idea to use for this application - it's subjected to vibration, which will work-harden the copper and it will eventually crack. The older OEM Corvette applications used what LOOKS like copper tubing, but it isn't - it's copper-plated STEEL tubing, just for that reason. The plastic (nylon) tubing will work just fine, as long as it's routed so it doesn't rub on anything sharp and you use a rubber grommet where it passes through the firewall.
JohnZ
CRG
'69 Z28 Fathom Green
JohnZ is offline
post #4 of 5 (permalink) Old Dec 30th, 02, 05:58 PM
Gary
I've had no problems with the plastic tubing. If I ever change gauges, I will go with the electric instead.
69 convertible,fully restored, well almost.
Gary Dorion is offline
post #5 of 5 (permalink) Old Dec 30th, 02, 06:44 PM
I bought an Autometer copper tube for $10. came with all necessary fittings and firewall grommet. Is this a bad kit?
matth is offline
