Fuel Sender Calibration - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 16th, 03, 06:00 PM Thread Starter
Matt Jones
This is for my '86 Chevy 1/2 Ton...but should be similar to a Camaro.
The problem I have is the calibration. When the gauge gets to empty, I actually have 8 gallons left (20 gallon tank). The sender and gauge seem to work properly, since it has the capability to go from empty to full. The weird thing is, this happens on both tanks!
I assume I have to bend the sender float? Has anybody had to do something similar? How far does the float have to be from the bottom of the tank?
Matt Jones
1969 Base Camaro
Vortec 355, Perf. RPM, Demon Carb., TH-400
All sheetmetal is NOS GM
See my UPDATED webpage at: http://www.geocities.com/compuboy007/ (Updated: 1/13/03)
Silver69Camaro is offline
post #2 of 2 (permalink) Old Jan 17th, 03, 05:35 AM
Don't consider bending the float arms. Never heard of that being done. Without a schematic on that vehicle I'm making some assumptions but hopefully I'm close enough to get you started.
Since the problem occurs in both tanks I don't think it's the floats. Problem is something that is common to both tanks.
1, The tank senders are both tied to ground. Make sure that there is a good body ground. On your Camaro it's the ground strap from battery (-) to the right inside fender. Maybe an 80s truck is in the same place.
2, Possibility that the tank selector switch is acting up. Think I would check the gage first.
3, I assume that the sender is the same as your car. That is, it goes from 0 = empty to 90 ohms = full. Using that assumption, use the method Mike describes in the Chevelle thread to see how the gage responds using fixed value resistors in place of the sender input. (inside the attached thread) That should give you an idea if the gage or calibration resistor are the problem.
Perhaps someone else will have a better idea, but best I can do off the top of my head.
https://www.camaros.net/forum/Forum10/HTML/001796.html
John_Muha is offline
