Dash Speaker, what size? - Team Camaro Tech
post #1 of 8 (permalink) Old Aug 7th, 01, 07:06 AM Thread Starter
I am in the process of wiring and installing an complete stereo system in my 1969 convertible Camaro. I just pulled out the original center dash speaker (yes it actually worked).
I want to use this space for a center channel speaker. I am looking for recommendations on speaker size for this area.
I have seen the two speaker system in the restoration catalogs but what about a 4X10?
jrager is offline
post #2 of 8 (permalink) Old Aug 7th, 01, 10:50 AM
Steven
You need to think in terms of the total system setup ... how many channels ... any amps, a sub ??? ... Minimally, you would expect to see 4 channels ( speakers ) and maybe a sub ... balance you speaker placement ... think in terms of pairs of speakers ( excl sub ... you can get by with 1 sub ) and some degree of symmetry ... A "center" spear is more of a home theatre term or application ... match your speakers and balance your sound ... good luck
sdtsdt is offline
post #3 of 8 (permalink) Old Aug 7th, 01, 11:26 AM Thread Starter
Thanks for the reply.
I will be installing 5 1/4" components in the front and rear of the car with two 10" or 2 8" subs in the rear seat/trunk area.
I wanted to take advantage of the center speaker housing in my Camaro and use it as a center channel.
I have two 4 channel amps (50watts X 4). One will drive the 2 components and the center channel. The other amp will be bridged down to drive the subs (110watts X 2).
I know that if I upgrade to a DVD system that it will require a center channel.
I think I am going to go with a 4X10" in the dash.
This system should rock when completed.
jrager is offline
post #4 of 8 (permalink) Old Aug 7th, 01, 06:11 PM
Steven
darn man, I am envious ... sound like this thing is going to be rockin' ... I admit, a slick audio hook-up is just as great as some of the other mechanical and cosmetic hook-ups ... I hope it all come together for you ... you have given me a couple of new ideas ...
sdtsdt is offline
post #5 of 8 (permalink) Old Aug 7th, 01, 06:13 PM
Steven
by the way, why not a 6 x 9 instead of the 4 x 10 ?
sdtsdt is offline
post #6 of 8 (permalink) Old Aug 7th, 01, 08:47 PM Thread Starter
I measured the original speaker that was in the dash and it looked like a 4X10 would be just about the same size as the original.
6X9's may be to much for a center channel.
The Original dash speaker was about 5"X11.5"
I did consider 6X9's in the rear but components sound so much cleaner. It is a tough call.
I will be wiring the center speaker with one positive speaker wire from the left and one negative from the left. I am a bit concerned with the center speaker overpowering the front right and left but will have to try it before I go out and buy another amp and crossover Just to run a center channel.
jrager is offline
post #7 of 8 (permalink) Old Aug 8th, 01, 08:34 PM
Gary
The center speaker is 4x10. I'm putting in the 4x6 kick panel speakers, and the 2 speaker set up for the center dash for the 8-track radio I got. I knew my old tapes would come in handy, just had to wait 25 years.
Gary Dorion is offline
post #8 of 8 (permalink) Old Aug 9th, 01, 03:13 PM
i have one of those two speaker systems from the resto catalog...easy to install and the highs are incredible! they don't hold too much bass though.
Garrett M.
68 Convertible
Cam35068 is offline
