Speedo and Tach options - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 13th, 04, 11:10 AM Thread Starter
I'm trying to decide between a stock tach and speedo and 5" Auto Meter units. If I go with a stock tach (in place of the fuel guage) will that require a new circuit board designed for a tach in that location. If I go with the 5" ones, will I have to wire the turn signal ect. that are now on the circuit board. What other type of things need to be addressed in either swap.
Viva La France...She's always there when she needs you
HeadHunter is offline
post #2 of 7 (permalink) Old Mar 13th, 04, 04:14 PM
What year? I assume by what you said it is either a 68 or 69, since the 67 does not require a new circut "board". I swiched and kept the stock Tach in my 67 and added a fuel gauge and low fuel warning light in the area beneath the "ash-tray".
WillS is offline
post #3 of 7 (permalink) Old Mar 14th, 04, 11:01 AM Thread Starter
Sorry, WillS...it is a '69. I have added a console w/guages which includes a fuel guage. I have a "MonsterTach" w/shift light on the dash now, but I have a new dash pad I want to install and I dont want to drill holes in the new one. So I was going to do what I talked about in the first post. But, cruise-in season is upon us in the South and I don't want any surprises to keep me in the garage for any length of time. Does the indash Tach require a special circuit board? Maybe I should make a bracket to go over the dash pad and attach to the metal part near the window and keep what I have.
post #4 of 7 (permalink) Old Mar 15th, 04, 08:45 AM
In Dash Tach just requires the correct wiring there is no Circ. Board
< edit > did you use the Autometer Gauge pod or a Factory set up ?. If its a factory set up you should have the tach wiring in the Harness that was needed for the console gauges.
Rsmith1969 is offline
post #5 of 7 (permalink) Old Mar 15th, 04, 01:45 PM
Jeff
I have a Tach harness on ebay right now. There is a picture of what it looks like.
Item number: 2466590190
[ 03-16-2004, 07:33 AM: Message edited by: DjD ]
A69RS is offline
post #6 of 7 (permalink) Old Mar 15th, 04, 08:39 PM
A69rs watch how you post in here that sorta looks like you are trying to sell him that harness and if Dennis sees this he will probably kill your post because selling is a No No on the message boards. so keep that in mind please
post #7 of 7 (permalink) Old Mar 16th, 04, 02:37 AM
Administrator
Al McKenzie
It's mainly the posts where the topic is an ad that gets toasted.
Al is offline
