wiring for idiont lights vs z28 guage clusters (swapping) - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 3rd, 01, 03:28 PM Thread Starter
I have a chance to buy a guage cluster out of a 79 Z28 for my 78 camaro to replace the idiot lights. This comes with no sending units or wiring. Will this work, and what wiring changes do I need? Am I better off to try and get one from a junkyard with wiring and sending units? What all is involved in changing this out? Is this a nightmare?
Does GM sell all of the wiring stuff and sending units I need still? How much am I looking to spend? The cluster is $50, I can get a brand new cluster (unused) with all sending units and maybe wiring (maybe not, i forgot) for $250.
If I do go to a junkyard, will a trans am cluster be the same?
HELP!!!! I'm putting in a 400 small block so I really want to monitor my engine, esp. the water temp. I could go with the 30+ year old Stewart Warner guages that I have (unused if anyone wants to make an offer) but there is really no room to put them under the dash unless I want to fill in the non-functional A/C vent in the middle of the dash pad. The cluster will look 100% better than the other options, so I am leaning towards that.
Thanks,
Chuck
oh yeah, anyone know what years came with map pockets in the door panels? I'm searching for some.
Chuck78 is offline
post #2 of 4 (permalink) Old Jan 4th, 01, 07:10 AM
Chuck, It is relatively easy to replace you clusters. I just put a 78 in my 70. You do not need any additional or different wiring. All that is required is to change where some of the wires plug into the connector. The only part I had to buy was a new single spade temp sending unit, about 8 bucks. I have a detailed set of instructions I will e-mail to you. Just be patient as I have to find them first. Remember the gage pod willl not have an oil gage. Why they left this out I don't know but I "hid" one on mine and just t'eed into the original sending unit so the idiot light would still work.
onemorecamaro is offline
post #3 of 4 (permalink) Old Jan 6th, 01, 05:35 AM Thread Starter
Okay. 79 and later clusters have the turn signals in a slightly higher location, so the $50 79 z28 cluster won't work unless I fabricate a new aluminum bezel for it. Good luck getting that to look right...
So now I'm looking at a 70 cluster with the 150mph speedo. I have a 130mph speedo now. Will this 70 cluster work in my 78? The turn signals at least look like they're in the right place.
here is a pic (hope it shows up):
and here is the 79:
Thanks,
Chuck
[This message has been edited by Chuck78 (edited 01-06-2001).]
Chuck78 is offline
post #4 of 4 (permalink) Old Jan 6th, 01, 07:47 AM
The 70 should work in your '78. At a minimum the guages can be interchanged from one pod to the next including the speedo if you want to retain your 78's odometer reading. Otherwise I like the 70 speedo as it is a 150mph and has no kilometer scale. If all else fails I have a '78 guage cluster I will send to you for cheap. i.e. $25 including shipping.
