Front turn signal - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 27th, 03, 06:27 PM Thread Starter
I replaced my wiring harness in my 68 camaro and I lost my little connecters that plug into the back of the front blinkers, not the part that holds the bulb, just the two wires that snap in. I cant seem to find just the connecter anywhere. Any ideas??
Yellow68SS is offline
post #2 of 3 (permalink) Old Jan 28th, 03, 06:15 AM
A couple of suggestions but no definite answer. If you can't locate a used connector try searching around through this information and you might find something.
AC/DELCO pigtails catalog that might have what you are looking for. It is catalog # 16A-101. Go to your local AC-DELCO parts retailer and see if they can help you.
Try the "Global Connection Systems Catalog" from Delphi Automotive Systems. This might have the connector housings and pins that you need.
John_Muha is offline
post #3 of 3 (permalink) Old Jan 28th, 03, 06:17 AM
Most GM cars in this time frame used the same connector. Go to a salvage yard and rummage through. Carry a set of wire cutters.
Welcome to the club! Lots of good info and people here........
Everett "OBJECTS IN THE MIRROR APPEAR QUICKLY UPON RAPID DECELERATION"
Everett#2390 is online now
