RS hrn rly wiring - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 31st, 03, 01:07 PM Thread Starter
My wiring was messed up when I purchased the car so I cannot compare to old, I also have the 67-69 rs console guage and headlight book with all diagrams, and factory assembly manual, but still I can tell which wires go to the horn relay except for the two plug connectors.
The 14g that goes to the horn goes to which terminal on the relay?
Then there is also a 20g with plug, which terminal does it go to?
As I look at the bottom of the relay terminals are numbered, terminal 4 is the stand alone terminal in the lower right corner,looking at the bottom, when the two screws are facing away from you. Is terminal 4 where the horn lead goes? a guess on my part due to a design in the harness plug. So now still looking at the bottom of the relay, there are two male spade connectors one above the other, which of these is used? based on my theory that the horn goes to terminal 4?
hope I'm not being a total idiot here, the schematic shows the horn all the way left, maybe i'm not following a rule here on termianal to wire orientation.
p.s., I have searched past posts and they were not conclusive, the one that had a drawing link, the link is no longer, i'm just trying to figure which of the two wires with plugs go on the three available male spade connectors.
Thanks,
Jerry
[This message has been edited by sherr20 (edited 01-31-2003).]
sherr20 is offline
post #2 of 2 (permalink) Old Jan 31st, 03, 10:00 PM Thread Starter
Well, after a very in depth search here into the wee hours, I think I found my answer, the search for horn relay turned up more hits this time and I found it...kind of aggrevating, but i'm sure you guys that have been on here a while just go "not that one again"
sherr20 is offline
