blowing fuse!! need help!!! - Team Camaro Tech
post #1 of 3 (permalink) Old May 26th, 03, 06:16 PM Thread Starter
1985 iroc every time i turn on the headlights i blow my courtesy lamp fuse. No running lights,no dash lights could this be my headlight switch? Any help would be appreciated.THANK IN ADVANCE!!!
big texas is offline
post #2 of 3 (permalink) Old May 28th, 03, 10:13 AM
You should check the wires where the headlights are. They might be corroded where the battery is. My fan kept doing the same thing. I took off the battery and noticed that the fan wires were being crushed and corroded by the battery being on top ov them. I had to replace the wires. Make sure that isn't happening to you.
4U 2 NV is offline
post #3 of 3 (permalink) Old May 28th, 03, 05:45 PM Thread Starter
Thanks I'll check it out and let you know!!!
