68 RS headlight hoses - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 24th, 04, 07:13 AM Thread Starter
Ok, I have just bought a new hose kit from Biscay's classic cars. When I got the car the headlight system was not put in but had all new stuff up front. The actuators are there and work.. and the tank reservoir as well. …and a new switch. My problem is what hose goes were? The hoses are color coded … does anyone know of a chart or diagram to help run these things? … thanks.
Ken/68RS is offline
post #2 of 5 (permalink) Old Feb 24th, 04, 07:23 AM
click's Avatar
Ken welcome to Team Camaro the Tech Info. link on the main screen of Team Camaro has 2 series of links to articles, the new series 2 part has this link to 69 RS vacuum info. that Moderator Dennis made up for us.
It should be very similar to your 68, give it a read and see if you can make it all work.
[img]graemlins/thumbsup.gif[/img]
69 RS hose routing and Vac info.
click is offline
post #3 of 5 (permalink) Old Feb 24th, 04, 08:59 AM
DjD
DjD's Avatar
Ken - the biggest difference I believe is your '68 vacuum tank has two fittings for hoses. the '69 has one and a tee. If you look at the diagram in the tech reference article I think you will be able to see all you have to do is remove the tee and run the black to the tank.
I do need to get off my butt and research the '68 more and do an additional page for it. Some day I guess. [img]graemlins/clonk.gif[/img]
...Dennis
DjD is offline
post #4 of 5 (permalink) Old Feb 24th, 04, 10:36 AM Thread Starter
Angry
thanks guys... it gets me started anyway.
Ken/68RS is offline
post #5 of 5 (permalink) Old Feb 25th, 04, 03:57 AM
Will work either way (with the T and pluging the extra connection at the tank or running straight to the tank).
The thing to remember is until the reservoir is able to hold a vacuum the actuators won't work anyway.
CA420 is offline
