engine cooling fan switch - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 19th, 01, 04:32 PM Thread Starter
Does anyone know of an engine cooling fan switch that screws into the intake manifold that passes voltage when closed. (not the grounding type) I would like one that closes at 195-200 degrees and opens at 185-190 degrees so i can run a 180 degree thermostat. I plan on using this switch to pick up a relay to control the engine cooling fan.
smallblock is offline
post #2 of 2 (permalink) Old Jan 20th, 01, 03:35 PM
JohnZ's Avatar
See the electric cooling fan section of the Summit catalog - "Jet" makes several of these that turn on and off at different temperatures - used one on my tube-frame Grand Sport. E-mail me if you don't have the catalog and I'll give you the info.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
