fuel gauge - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 20th, 17, 06:26 PM Thread Starter
Probationer
randy
fuel gauge
What would make my fuel gauge register way past the full mark & not move .
What would make the fuel gauge on ,my'67 , go way past the full mark & stay there.?
rrickard is offline
post #2 of 3 (permalink) Old Aug 20th, 17, 07:22 PM
Jonathan
Have you verified your float is working on the tank? It provides resistance to the gauge on mine.
Red6a1 is offline
post #3 of 3 (permalink) Old Aug 20th, 17, 08:51 PM
69-Pace's Avatar
Re: fuel gauge
Randy - Merged your two threads into one, then moved to Electrical forum. This is a very common issue and 9 out of ten time is a bad ground or sender unit.
Run the diagnostic troubleshooter that is a sticky in the Electrical forum for Failed Fuel Gauge Issues.
https://www.camaros.net/forums/19-ele...n-69-pace.html
Run through all the steps to determine if it is sender or ground or wiring. Then post your results here and we will walk you through the fix.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
