ignition switch on top of steering colum. - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 1st, 05, 12:40 PM Thread Starter
does this switch also supply the power to the coil when the key is turned into the on position. / thank you
69copo540 is offline
post #2 of 5 (permalink) Old Feb 2nd, 05, 02:25 AM
If it is in IGN position, yes. ACC position, no.
post #3 of 5 (permalink) Old Feb 2nd, 05, 01:04 PM Thread Starter
so when i turn the key forward without engaging the starter and i have no power at my coil wire my nuetral safety switch is the problem./ thanks everet
post #4 of 5 (permalink) Old Feb 2nd, 05, 01:11 PM Thread Starter
ok let me be more direct . some years ago i let a friend install an msd box for me while i was away . he smoked something and there was no power to the coil wire. so i jumped one from the fuse block directly to the boxe,s coil wire lead that came on when i turned the key . now that i have the car completly torn apart to make many changes and had the harness off the front i noticed the wire on the bottom left of the left side harness connector in the engine compartment was cooked. so i fixxed the connection thinking this was gonna solve the problem. well it didnt. the ignition switch on top of the colum is new and in perfect working order and been tested. the only thing i can think of left would be the nuetral safety switch. nothing else in the harness is cooked all checks out clean and carry,s a path of current. if anyone knows i need help . this is all thats holding me from firing and driving off and after 2 years hard work and lotsa bucks i want to go for a ride. if u need and pic,s of the location on the outter firewall just ask and provide me with a e mail to send them to thanks. also is there a way to test this switch./ thanks
post #5 of 5 (permalink) Old Feb 2nd, 05, 01:36 PM Thread Starter
NEVER MIND PROBLEM SOLVED. my bumb arse by not paying attention when i fixxed the smoked connection plugged it back into a blank socket thus resulting in no power at the coil wire . im goin for a drive . thanks guys for all the help and info..
