Tail light problem - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 25th, 17, 10:55 PM Thread Starter
Probationer
Mary
Unhappy Tail light problem
Hi, new person here. We have a 69 Camaro SS. Found we have a tail light problem. Of the three lights, the outside light will light for brakes and turn signal, but the inside light will not light for brakes or turn signal. New bulbs and checked ground wire. What do we check next?
redsat1632 is offline
post #2 of 7 (permalink) Old Aug 26th, 17, 04:32 AM
kevin
Re: Tail light problem
do you have voltage in that socket ?
flat tire is offline
post #3 of 7 (permalink) Old Aug 26th, 17, 07:27 AM
Only the outside bulb is used for tail, brake, & Turn.
Brown for tail, Yellow for brake/Turn on Drvr side, Dark green forTurn/Brake on Pass side.
The inside is tail only - brown wire.
Middle is back-up lamp.
Name:	1969 Rear Lights.JPG
Everett#2390 is online now
post #4 of 7 (permalink) Old Aug 26th, 17, 07:39 AM Thread Starter
Probationer
Mary
Not sure, will check. Thank you
post #5 of 7 (permalink) Old Aug 26th, 17, 07:43 AM Thread Starter
Probationer
Mary
Ok, guess I gave wrong info. I thought both outer lights worked the same. Husband just agreed with you. When using parking lights, the third lamp (inner, not the middle) won't light.
post #6 of 7 (permalink) Old Aug 26th, 17, 09:40 AM
Kevin
KevinW's Avatar
Mary, for a regular Camaro (not an RS), having only the outer perform parking brake/turn is normal and the way it was set up from the factory. The inner lamp is for parking light only. But modern single filaments may be as bright as a brake light. Attached is a post that deals with the brightness issue, but it a bit old and the availability of #67 and #97 bulbs that fit may have changed.
https://www.camaros.net/forums/19-ele...amp-bulbs.html
I think this was the one used in my car and the example thread: Sylvania long life 67
Kevin
KevinW is offline
post #7 of 7 (permalink) Old Aug 26th, 17, 02:25 PM Thread Starter
Probationer
Mary
Thanks for all the help. I think we got it solved. Appreciate the help.
