Weird electrical problem... - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 26th, 04, 07:22 AM Thread Starter
Exclamation
I've posted this on the Team Chevelle site as this is a Chevelle related issue, but I usually like to post things like this on both sites to get different types of exposure, so sorry if anyone has to read this again [img]graemlins/waving.gif[/img]
My car was working just fine as I pulled into a parking lot, nothing out of the ordinary. I got in an hour later and turned the key. My generator light was on (although dim), with the right turn signal lit up. The lights inside turned on and were dim, and dimmed more when I would tap the brake. My CD player would not light up. Later I found turning the key causes the passenger light and signals to turn on at full brightness (even with lights off), and the drivers lights on and dim. When I turn the lights on manually, it's the same thing, but no tail lights. However, when I open the door, or turn on my dome light with the key off, the inside light works fine. I tried jumping a few times, and it only bumped (and a quick, split second bump) twice. The car is now towed home. I can't find anything in the dark so I'm going to wait till tomorrow after school to fix this. I'm trying to look for suggestions though. When the car was working, my headlights and dashlights would like to get bright and dim, and my blower motor would blow harder and softer, and they seemed to correlate, which made me think something like voltage regulator? I don't really know anything electricl so I'm in the dark on guessing that, but that seemed to make sense. If it completely went kaput, would that cause these symptoms, or do I have a bigger problem than I think? I would like to fix this asap as this is my daily driver, but I know it's probably going to take a lot of time with voltemeter. I've checked all grounds I could easily see in the engine compartment, and tried to check the fuses. If any of this needs clarification I'll be on here for a while to help. Thanks a lot in advance.
1971 Chevelle SS, matching numbers...350/TH350.
soccerguy045 is offline
post #2 of 2 (permalink) Old Mar 26th, 04, 11:06 AM
Sounds like a ground issue. I suspect the fender to negative cable ground but could be elsewhere. The thing about light circuits is that they can operate no matter which direction the current is flowing. Can cause some pretty weird results. Use a volt meter to measure between the negative post and fender and then between the negative post and block. For grins measure between the block and fender. It would also be good to have a helper tweaking the key switch while you do this. All readings should show no more than a few thenths of a volt drop.
dnult is offline
