67 tach - Team Camaro Tech
post #1 of 7 (permalink) Old Dec 5th, 04, 08:22 AM Thread Starter
Leonard
Exclamation
I have a 67 with factory tach.The original engine was a 325hp 396.It now has a 454 with HEI ignition.Tach does not work,are they compatable?Do I need a new or different tach?I want the stock looking in dash tach.Help!! [email protected]
big block rsss is offline
post #2 of 7 (permalink) Old Dec 5th, 04, 11:26 AM
Brandon
Check your connections then.. the tac will only see a V8 not ci.
Brandon J. licence 1NASTY67
Nantooch is offline
post #3 of 7 (permalink) Old Dec 5th, 04, 11:27 AM
This is a pretty common problem. It can usually be fixed by installing a "filter" in the tach wire coming off the hei. It's been twenty years since I had to do one, memories figgy, but try a search, or perhaps check at msd.com, I think they have one.
post #4 of 7 (permalink) Old Dec 6th, 04, 06:04 PM
did it work before?
mybitchincamaro is offline
post #5 of 7 (permalink) Old Dec 7th, 04, 03:11 AM Thread Starter
Leonard
It worked at first then quit!
post #6 of 7 (permalink) Old Dec 7th, 04, 04:51 PM
as in when you first fired it with the hei, ot worked for a while, then don't work no more?
Unless the wire fell off, I think that would be bad....
post #7 of 7 (permalink) Old Dec 8th, 04, 04:42 AM Thread Starter
Leonard
any hints on removing tach from dash will be greatly appreciated.Anyone ever use Redline Gauge for repair service?
67 coupe,454-4sp
64 Impala ss
