Electric choke wire - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 23rd, 00, 10:37 AM Thread Starter
stevo camaro's Avatar
Is it acceptable to run a lead off the coil wire to supply the electric choke? Or should I unwrap all the wiring and find another wire thats hot with ignition on?
67 SS 396,4-sp
67 RS 327,4-sp
72 RS 350/350
69 4X4 suburban 350,4-sp
73 3/4 ton 454/400
http://www.geocities.com/stevocamaro
stevo camaro is offline
post #2 of 6 (permalink) Old Sep 23rd, 00, 02:05 PM
mccorry's Avatar
I ran mine off the coil hot...no problems...
mccorry is offline
post #3 of 6 (permalink) Old Sep 23rd, 00, 04:10 PM
JohnZ's Avatar
Running it off the coil hot terminal only gives the choke coil 5-7 volts (coil only gets full 12 volts with the ignition switch in the "start" position), not the 12 volts it wants to fully heat up and fully open the choke. May not make too much difference, but the choke coil does require 12 volts for full heating.
JohnZ
'69 Z28 Fathom Green
JohnZ is offline
post #4 of 6 (permalink) Old Sep 23rd, 00, 05:24 PM
mccorry's Avatar
DOH! John is right....
I didn't think that he could be running points. I am running an MSD which has 12V to the coil all the time...
mccorry is offline
post #5 of 6 (permalink) Old Sep 24th, 00, 03:31 PM Thread Starter
Thumbs up
Thanks guy's. I'm running points for now. so I guess I'll look for another wire.
67 SS 396,4-sp
67 RS 327,4-sp
72 RS 350/350
73 3/4 ton 454/400
post #6 of 6 (permalink) Old Sep 27th, 00, 04:21 AM
Stevo - I asked about this back in June under general tech and several recommended using the wire that connects to the windshield wiper motor. It is only on when the ignition is on and I'm told supplies enough power to make the choke activate. Hope this helps. (My post was 6/23 I think if you want to research back).
denverRS/SS is offline
