ignition - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 23rd, 04, 01:49 PM Thread Starter
Hello, I recently changed my points system to electronic. I disconnected some wires from my coil and did'nt write them down. I have a wire going to my starter, and two wires to the fuse block via the firewall, one of which is aluminum, that i was tracing in order to replace with copper to get the correct voltage to the coil. I can't remember which wire goes where.I beleive the wire i'm replacing goes to the positive side of the coil but can't remember where the other two go. I know it sounds stupid and i shoud have wrote them down, but like many , i had a few beers while working on my car, enough said. Any help would be very helpful. Thanks Denis
68 rs/ss 396-350hp<br />sunny daily driver
denis68 is offline
post #2 of 9 (permalink) Old Mar 23rd, 04, 02:36 PM
Steven
The yellow ( starter ) and the white clothlike ( resistor ) go to the positive side. The black wire ( from distributor ) goes to negative . Now, if you have a 2nd wire coming from distributor ( because of elec conversion you just did ) , it will probably go to a full 12 volt ( use ignition on fuse box ) ... The resistor wire does not carry 12 volts ( 7 to 9 volts instead ) . Check/Read your instruction to be sure on + feed wire for electronic conversion ...
sdtsdt is offline
post #3 of 9 (permalink) Old Mar 23rd, 04, 03:38 PM
That cloth wire (resistor wire) can be though of as a ballast resistor if your particular ignition instructions show one. But as sdt^2 said, electronic ignitions usually use a full 12 volts with no ballast resistor or resistor wire. But there are some that use both - a full 12 volts to the module and a ballast resistor or resistor wire to the coil.
dnult is offline
post #4 of 9 (permalink) Old Mar 23rd, 04, 04:00 PM Thread Starter
Thanks for the reply. Other than the cloth covered wire going to the fuse block , their is a brown wire. I'm pretty sure the cloth covered wire goes to the positive side but not sure about the brown wire. Denis
denis68 is offline
post #5 of 9 (permalink) Old Mar 23rd, 04, 05:34 PM
Does the car have a factory tach? If it does, the brown wire went to the negative side of the coil.
'67 SS/RS (RR)
'68 RS conv. (J2)
'68 Z/28 (VV)
'68 Drag Car(ZZ) 11.30 @ 118
'73 Corvette Drag Car 12.64 @ 106
Kyvox is offline
post #6 of 9 (permalink) Old Mar 24th, 04, 12:06 PM Thread Starter
Can I take the red wire from the new ignition module and splice it with the cloth wire and bypass the coil? I think they ran them both to the pos. side of the coil just for a termination point because the wires don't reach? Denis
denis68 is offline
post #7 of 9 (permalink) Old Mar 24th, 04, 12:28 PM
Steven
You need to refer to your instructions to see if the module requires a full 12 volts. What brand is the module/kit you installed? If you require a full 12 volts, your car may run erratic if the voltage is too low, so don't use the resistor ... If you require a resistor to step down the voltage, you can to run the red wire to the + side of the coil by extending the red wire by splicing in an extension ... Because the cloth wire is "unique", I would be inclined to leave it intact ... just my personal preference ...
sdtsdt is offline
post #8 of 9 (permalink) Old Mar 24th, 04, 01:08 PM Thread Starter
It does require 12v thats why I'm changing the cloth covered wire. I was told that this wire was aluminum and and transfered 9v to the coil on a 12v system so the points wouldn't burn up.
denis68 is offline
post #9 of 9 (permalink) Old Mar 24th, 04, 04:36 PM
Steven
Just run the red wire to the terminal marked IGNition on the fuse block...
sdtsdt is offline
