67 Turn Signal Switch Replace - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 5th, 17, 01:36 PM Thread Starter
frank
Frankrentef's Avatar
Anyone have step by step pictures on how to replace a 67 turn signal switch? I've seen several partial postings and articles, but none have (or the posting does not display due to age ) pictures.
THNX
67 Camaro RS - 383 Stroker
Factory A/C - Muncie 4 speed
Frankrentef is offline
post #2 of 4 (permalink) Old Sep 5th, 17, 09:43 PM
Re: 67 Turn Signal Switch Replace
From 67 Service Amnual, I think switch can be replaced without removing column.
Tilt included, so read and use steps as appropriate.
Hope I got them all.
Tip: in pulling switch with its harness out the top of column, you might attach a string to harness so when new harness goes in, you have a 'pull' for the new harness.
Hopefully, another member has done this feat and give better instructions.
Name:	Turn Signal 1.JPG
ID:	191457   Click image for larger version
Name:	Turn Signal 2.JPG
ID:	191465   Click image for larger version
Name:	Turn Signal 3.JPG
Name:	Turn Signal 4.JPG
post #3 of 4 (permalink) Old Sep 6th, 17, 07:38 AM Thread Starter
frank
Thnx!
post #4 of 4 (permalink) Old Sep 6th, 17, 09:38 AM
Russ
I replaced my 67 tilt-column switch many years ago, and didn't have to remove the column from the car. Car is PG auto with console shifter if that matters. I seem to recall there were two suppliers or styles of switch, Boyne and AC Delco, one being an orange color plastic versus white. Not sure if they are interchangeable.
Petes L48 is offline
