Driving lights wont work - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 5th, 03, 07:11 PM Thread Starter
Hey guys,
The other day I got cop backed into me and broke my grill and head light. Now both head lights don't work. So until I get them fixed I got a pair of HELLA driving lights. I wired them like the schematic says but they wont light up. I thought that may I didn't wire it up right. When you put the power wire up to the battery you can hear the relay "clicking". So I hooked up the battery straight to the light and bipassed all the wiring, switches and relay to see if it would work and still will not light.
Any suggestions on how to test it?
Tony
obnoxious 67 camaro under construction. TH350/383 stroker w/ aluminum Edlebroc RPM heads,cam, and carb. Guldstrand mod, Hotchkis 600lbs springs. Next Hotchkis swaybar and disc brakes.This is a "Daily Driver" that still needs A LOT of work.
OBNXUS67 is offline
post #2 of 3 (permalink) Old Feb 6th, 03, 03:24 PM
JohnZ's Avatar
The lights need a ground - if you run a jumper from the battery (+) to the feed terminal on the light and another jumper from the light's ground terminal to the (-) side of the battery and the lights don't work, the lights are bad. If they work, you don't have a good ground in the existing wiring.
JohnZ
CRG
'69 Z28 Fathom Green
JohnZ is offline
post #3 of 3 (permalink) Old Feb 6th, 03, 05:27 PM Thread Starter
Thanks,
Ill try it again.
OBNXUS67 is offline
