Temp Gauge - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 11th, 00, 03:55 PM Thread Starter
Thumbs down
I started up my 87 camaro 305 yesterday, when it was 15 degrees out, and the temp gauge was maxed out at 800 degrees. I was wondering if i need a new thermostat?
icenine9 is offline
post #2 of 4 (permalink) Old Dec 11th, 00, 04:17 PM
WOW!!! Your engine is really HOT! No, seriously, sounds more like your temp sending unit is out. depending on the circuit, if you measure across it, it will either be a dead short or wide open.
kdorsett is offline
post #3 of 4 (permalink) Old Dec 11th, 00, 07:06 PM
Ha!! Will a 305 even produce exhaust close to 800 degrees????
Justin
-1967 Camaro SS350
www-student.furman.edu/users/j/jtrauner
jrt67ss350 is offline
post #4 of 4 (permalink) Old Dec 13th, 00, 06:08 AM
Smile
The exhaust manifolds will not to 800 degrees, but it will get hot enough to melt the insulation on the sending unit wire, causing the gauge to pin...
68ragtop is offline
