RS Headlights 1967 - Team Camaro Tech
 1Likes
  • 1 Post By Ric67
post #1 of 8 (permalink) Old Sep 19th, 17, 02:55 PM Thread Starter
Probationer
Ron
RS Headlights 1967
Looking for help with my headlight doors. They both open but only the right one closes. I replaced the diode but it didn't solve the problem. Any ideas? Thanks
Woodwizard46! is offline
post #2 of 8 (permalink) Old Sep 19th, 17, 03:39 PM
Rick
Re: RS Headlights 1967
Does it close when you touch it ? Usually a loose wire or poor ground on one of the switches .
Rick
Mike_S likes this.
Ric67 is offline
post #3 of 8 (permalink) Old Sep 20th, 17, 08:31 AM
Michael
Check that the ground wire coming out of each switch has a good ground to the switch mounting bracket.
67 LOS SS/RS L35 Hardtop - Original w/UOIT
67 NOR SS/RS L35 Convertible - Restored
Mike_S is offline
post #4 of 8 (permalink) Old Sep 20th, 17, 01:53 PM Thread Starter
Probationer
Ron
Thanks Mike, I'll check them.
post #5 of 8 (permalink) Old Sep 21st, 17, 07:28 AM
You also might remove the relay board on drvr fender behind headlight bolted to fender and unplug/plug each relay connector for getting a better contact between terminals and relays.
My question is: Are relays hot to the touch after driving for over 15 minutes?
Mine are hot enough to fry an egg on.
post #6 of 8 (permalink) Old Sep 23rd, 17, 05:20 AM
Jonathan
Have you confirmed the door limit switch wires are in the correct order?
Red6a1 is offline
post #7 of 8 (permalink) Old Sep 23rd, 17, 05:59 AM
69-Pace's Avatar
Moved to electrical
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #8 of 8 (permalink) Old Sep 23rd, 17, 07:21 AM
Below is a link to a troubleshooting guide that will assist you. The relays mentioned in the link are still available at AutoZone for about $7 each. Hope this helps...
FAQ67
Old Dad's 67 is offline
