tic toc from tach - Team Camaro Tech
post #1 of 1 (permalink) Old Jan 22nd, 03, 04:48 PM Thread Starter
1968...clock is not working. how do you remove the clock from the tach? Do the clock hands just pull off the stem to remove the clock out the back? When I pull (if I pull) off the hands, do they just push back on the main stem? Is there any secrets to removing the clock from the tach mechanism? While I am here, does the speedo needle just pull off of its' stem? Thanks.....thud
f105thud is offline
