Rs circuit breaker - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 1st, 03, 05:29 PM Thread Starter
Just want to make sure of somthing, I purchased a new circuit breaker for my RS system (identical to the one Ricks first gen sells, and only $3.95 at carquest)
On the plastic case one pole is marked battery, the other auxilliary, can someone confirm that the battery marked side goes to the horn relay. Yes maybe very simple, but I want to make sure it is all right. Also, for those who need RS relays, these guys have them for $8.95 each, and they are AC Delco. http://www.gmpartsdirect.com/
sherr20 is offline
post #2 of 4 (permalink) Old Feb 2nd, 03, 03:19 PM Thread Starter
no takers???
sherr20 is offline
post #3 of 4 (permalink) Old Feb 3rd, 03, 06:14 PM
I'll take a stab at it since if I'm wrong someone will point it out. I'm looking at a chassis service manual for a 67 Camaro. The 67 RS had electric headlight doors, but there is no mention of it in the book or your email, so chances are it does not matter anyway. The Electrical diagram of the horn relay shows a red 10 gauge wire coming indirectly from the positive terminal of the battery. It also shows a 16 gauge brown wire from the horn relay to the fuse panel. The brown wire has a disconnect in it. If you are trying to put the circuit breaker on the 10 gauge red wire, obviously the battery side goes toward the battery. If it is on the brown wire, the battery side should lead to the horn relay.
jimbo1522 is offline
post #4 of 4 (permalink) Old Feb 3rd, 03, 08:28 PM
Jerry Cox
Sherr20, Yes the Batt side goes on the B+ side where every you get it from. It should come off of the horn relay. Have a great Day Jerry
67 Marina Blue RS
327 365HP, 700R4
Ocala FL
Ocala67RS is offline
