No electricity - Team Camaro Tech
 1Likes
post #1 of 18 (permalink) Old Oct 17th, 17, 05:30 PM Thread Starter
Apprentice
Reade
Question No electricity
Good evening fellow Camaro lovers, ha..
Was driving car today, for no apparent reason, all electrical power stopped, car stop running, radio quit and just glided on its own power into parking lot, won't take a boost off vehicle or battery pack, no lights, ignition, radio, etc, Any ideas? fuses? Battery completely dead?
Thanks ..
1967 Camaro Coupe
383 Stroker, 3000 stall, 750 Holley, 350 turbo trans, 373 12 bolt posi, cal tracs, hounds tooth and floor console..
Reademan is offline
post #2 of 18 (permalink) Old Oct 17th, 17, 06:16 PM
Bill
Re: No electricity
My first thought is the battery. Check it first. After that is ruled out, check the power junction box on the radiator support.
arocars is offline
post #3 of 18 (permalink) Old Oct 17th, 17, 06:30 PM
scblucam's Avatar
Re: No electricity
Check the bulkhead fitting in the engine compartment opposite the fuse block. If the bolt is not in and it pops off you are dead in the water.
68 302 M20 - 85 IROC Z
scblucam is offline
post #4 of 18 (permalink) Old Oct 17th, 17, 06:33 PM
Re: No electricity
Sounds like a blown fusible link at the battery. Check the wire for blistered or burnt insulation. If so replace that piece of fusible link.
If you added any electrical loads (radiator fan, electric fuel pump, a Giga Watt stereo amp, or even a death ray for when you get frustrated in traffic) to the car you may have to increase the amperage on the fuse and the size of your car's wiring to handle the extra power.
Big Dave
Larger Dave is online now
post #5 of 18 (permalink) Old Oct 17th, 17, 06:41 PM Thread Starter
Apprentice
Reade
Re: No electricity
Am going to take battery out of other car tomorrow and try that, if that doesn't work ,what do I look for at the power junction box .
Thanks for your help.
Reademan is offline
post #6 of 18 (permalink) Old Oct 17th, 17, 06:41 PM
Re: No electricity
Had that happen at near midnight coming home from the track at night on a dark road with no streetlights
Found it to be the battery ground at the motor was loose.
68 Camaro~LSx ~all motor
post #7 of 18 (permalink) Old Oct 17th, 17, 06:45 PM Thread Starter
Apprentice
Reade
Re: No electricity
Thanks everybody for ideas..
Drinking beer and watching hockey,
Will check tomorrow ..
ctcz28 likes this.
1967 Camaro Coupe
Reademan is offline
post #8 of 18 (permalink) Old Oct 17th, 17, 07:19 PM
Vega$69's Avatar
Re: No electricity
Junction terminal on the radiator support. all power to the car comes from the batt to the terminal and then to the buss bar on the horn relay.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #9 of 18 (permalink) Old Oct 18th, 17, 07:05 PM Thread Starter
Apprentice
Reade
Re: No electricity
Brothers from a different Mother,
Checked all your suggestions, all seemed ok ..put in a different battery and the car fired up immediately ..
I did note when removing the battery the negative terminal connector was a wee loose, could that have been the reason for the battery being dead? It is only a year old. Is there anyway to make sure the alternator is working properly..
Thanks again.
1967 Camaro Coupe
Reademan is offline
post #10 of 18 (permalink) Old Oct 18th, 17, 08:08 PM
Vega$69's Avatar
Re: No electricity
Yep. A loose cable will go it every time
Vega$69 is offline
post #11 of 18 (permalink) Old Oct 19th, 17, 05:07 AM
Bill
Re: No electricity
When cars are slow to start or need jump starts, my flawed, but semi-reliable test for alternators and batteries is this; at night, with the car running, turn the headlights on and rev the engine. If the lights noticeably brighten and fade with the revs, then I look at the alternator. If there's no real difference to the brightness of the lights, then I look at the battery.
Doing a search on here, I found: https://www.camaros.net/forums/19-ele...d-battery.html
arocars is offline
post #12 of 18 (permalink) Old Oct 19th, 17, 11:29 AM
Cruzin "the 82"
angelglo's Avatar
Re: No electricity
Thanks again.
That seems strange to me. after the car is started, the car is powered via alternator. So, if you were chugging along, the loose cable would not have been a factor.
please correct me if I'm wrong
angel
angelglo is offline
post #13 of 18 (permalink) Old Oct 19th, 17, 12:36 PM
Kevin
Re: No electricity
I remember that as being kind of a test but the other way around. Reving car up alternator puts out almost 15v and at idle at battery 12v, alternator/regulator is good. If no change your on battery voltage, alternator/regulator problems.
Get a voltmeter and measure at battery terminals and see if voltage increases to just under 15 when reved up. Poking around with a voltmeter to check things will tell where your issue is if it wasn't the battery.
I had an issue with my car that drained new battery overnight, got running the next day with a a jump, same thing day after. Turns out it was a bad external regulator drawing 1.2 amps with nothing turned on in car.
My '69 RS Primer driver project
KJProX is offline
post #14 of 18 (permalink) Old Oct 19th, 17, 12:38 PM
Jimmie-Retired
Re: No electricity
I believe that was true at one time but I'm not sure with all the computerization in cars today. I know that my 69 will run with the battery disconnected but have never tried it on my newer car. You didn't specifically say what car that you were driving. You just said "my car".
Probationer.....Sad that you had to waste money on a new battery and it looks like it was just a loose/dirty terminal. The battery terminals are the FIRST place to look when you have no power and if it was your Camaro, it is strange that it just shut off. A bad cable would keep it from starting but shouldn't cause it to just shut off.
Jim's '69
68 SS 396 4 speed A/C Bought New Sold 1976
68 350/350 A/C Bought 1978 $700 Wrecked
69 350 4 Speed Bought 1988
Fried Okra is offline
post #15 of 18 (permalink) Old Oct 19th, 17, 02:15 PM
Agree with Fried Okra
First place to check is cable clamps to post interface.
Battery post tool is used a lot
Everett#2390 is online now
