pressing brake pedal causes instument lights to come on - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 11th, 17, 08:48 PM Thread Starter
Robbie
1967 Camaro rs/ss BBC 5spd console/gauges.
When I press the brake pedal, the instrument lights come on. Just got my car back from the paint shop. The wiring is replacement stock type AAW and is fairly new. I disassembled the car for paint and just reassembled everything. Everything plugged back together as it was before. Everything works with the exception of the aforementioned issue.
Not sure where to troubleshoot this problem.
Thanks in advance for any input.
Rob
Gyrine is offline
post #2 of 4 (permalink) Old Nov 11th, 17, 08:51 PM
Vega$69's Avatar
Re: pressing brake pedal causes instument lights to come on
Grounds
Vega$69 is offline
post #3 of 4 (permalink) Old Nov 12th, 17, 07:57 AM
Fred
77thor's Avatar
Originally Posted by Vega$69 View Post
Grounds
^^^ Yup.... I'll bet you missed a ground somewhere.
77thor is offline
post #4 of 4 (permalink) Old Nov 12th, 17, 05:07 PM Thread Starter
Robbie
Everyone, thanks for the feedback. It turned out to be a grounding issue...go figure. I installed star washers on a stud on each of the tail housings and the instrument panel no longer lights up when I press the brake pedal.
Gyrine is offline
