ash tray lamp - Team Camaro Tech
 1Likes
post #1 of 16 (permalink) Old Nov 21st, 17, 02:41 PM Thread Starter
Apprentice
Blades
ash tray lamp
i got a new bulb put it in and its allways on there's no switch like glove box?
was it powered by dash lamps cicuit on on the ign on circuit ?
i know the cig lighter allways on could be prvious did a adjustment to something ?
67 cam
67 camaro base model 350 worked m22
front discs 3.08 rear open
bobbyblades is offline
post #2 of 16 (permalink) Old Nov 21st, 17, 02:59 PM
Michael
Re: ash tray lamp
Mine is IGN switched, but check the 67 AIM for accuracy.
mahunt is offline
post #3 of 16 (permalink) Old Nov 21st, 17, 03:18 PM
Ed
bertfam's Avatar
Re: ash tray lamp
Sounds like you have it plugged into the wrong connector on the fuse box. It should be plugged into the "LPS" connector as shown in the AIM and the below drawing.
Ed
Name:	PANEL LAMPS.jpg
Ed B. (but you can call me Bert!)
CRG -
bertfam is online now
post #4 of 16 (permalink) Old Nov 22nd, 17, 07:59 AM
Michael
Re: ash tray lamp
Terrible picture, but accurate description.
The interior lights are indeed plugged into the LPS or Lamps terminal.
mahunt is offline
post #5 of 16 (permalink) Old Nov 22nd, 17, 09:13 AM
Ed
bertfam's Avatar
Re: ash tray lamp
Mike, did you click on the picture to enlarge it? I thought it's actually a pretty good drawing!
Ed
69-Pace likes this.
CRG -
post #6 of 16 (permalink) Old Nov 22nd, 17, 05:33 PM Thread Starter
Apprentice
Blades
Re: ash tray lamp
don't have that lps connection i got a acc fused pin batt fused pin and ign fused pin
post #7 of 16 (permalink) Old Nov 22nd, 17, 05:37 PM
Vega$69's Avatar
Re: ash tray lamp
Use the batt pinned
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #8 of 16 (permalink) Old Nov 22nd, 17, 08:10 PM
Ed
bertfam's Avatar
Re: ash tray lamp
If you use the battery connector the lamp will always be on! You SHOULD have a "LAMPS" connector if you have a 67! Post a picture of your fuse box.
Ed
CRG -
post #9 of 16 (permalink) Old Nov 22nd, 17, 09:16 PM
Roger
rogerh's Avatar
Re: ash tray lamp
Ed these are pictures of a 67 Camaro fuse panel. The first is a picture of my fuse panel and the second one I found on the internet. You can see the labeling a little better on the second pic.
Roger
Name:	Fuse Panel.jpg
ID:	197489   Click image for larger version
rogerh is offline
post #10 of 16 (permalink) Old Nov 22nd, 17, 10:33 PM
Michael
Re: ash tray lamp
Ahh, a great picture of a 67 fuse panel and not the twin row illustration from above.
There it is, forth fuse up from the bottom.
Looks like a brand new fuse box too, very nice.
mahunt is offline
post #11 of 16 (permalink) Old Nov 22nd, 17, 10:55 PM Thread Starter
Apprentice
Blades
Re: ash tray lamp
Roger
ahh there you go the right one is it i may have to tap in the wire that's there i wonder what was done to have the ashtray lamp allways on even at key off
post #12 of 16 (permalink) Old Nov 22nd, 17, 11:10 PM
Roger
rogerh's Avatar
Re: ash tray lamp
I don't have a ash tray light but if you only want the light on when the ignition is on or in the accessory position you could use the ACC spade on the fuse panel.
Roger
rogerh is offline
post #13 of 16 (permalink) Old Nov 22nd, 17, 11:20 PM Thread Starter
Apprentice
Blades
Re: ash tray lamp
ok found a connector with two gray wires plugged in the batt pin one was snipped off ? also i found the gray wire from ashtry socket running to a wire nut connected to the cig lighte r line what a jumble wonder where thwe unsnipped gray one goes
i just pulled that grey wire and socket out completely no need for ashtray lamp safer
post #14 of 16 (permalink) Old Nov 23rd, 17, 09:38 AM
Ed
bertfam's Avatar
Re: ash tray lamp
I could has SWORN there was a spade in the "LAMP" slot but looking at the two pictures, it's empty on both fuse boxes! Maybe old age is getting to me.
Ed
CRG -
post #15 of 16 (permalink) Old Nov 25th, 17, 03:49 PM
Bob
Re: ash tray lamp
Ed
Ed you are correct in that there is a spade terminal in the "Lamp" slot and it is used to power the ash tray light (RPO U28) with the dash lights on. Second spade terminal in "Lamp" slot was never installed at factory.
Bob
Big Iron is offline
