"BATT" terminal on fuse block now dead - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 7th, 18, 04:25 PM Thread Starter
Brett
Is the "Batt" spade terminal on the fuse block connected to a fusable link? For some reason I do not have 12 volts to that terminal anymore. Theres a fusable link next to the horn relay. How can you test these links? Also, how do you replace them?
Brett......
Rockets Up In 2020!
Brettallen59 is online now
post #2 of 3 (permalink) Old Jan 7th, 18, 04:43 PM
Re: "BATT" terminal on fuse block now dead
BATT spade is protected by the Courtesy Light fuse
BPOS is offline
post #3 of 3 (permalink) Old Jan 7th, 18, 04:50 PM Thread Starter
Brett
That fuse is good....I will replace it with another, but I looked at that one and it was good.
No, you were right! that was it. Thanks! you are superman!
Brett......
Rockets Up In 2020!
