69 X77 Tach and center gas gauge advice - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 27th, 18, 06:26 PM Thread Starter
Hi All, Going to install factory style tach and center gas gauge in my 69 X77, originally no tach or gauges, just idiot lights. Any advice on who would be the best source cost and quality wise? Does anyone sell the conversion as a package? It's an 02B car so it looks like in that build era I could go with either a 7 or 8k tach.
If I'm correct I will need the tach, the center gas gauge, a bezel for the gas gauge, and a conversion harness for the tach. I will modify the dash bezel to accommodate the tach.
Thanks if you can shed some light on the project, i.e. ins and outs, shortcuts on the process, etc, Thanks for reading folks!!!
Mostly Camaros and FINALLY a Double Nickel
Yellow69RSZ is offline
post #2 of 2 (permalink) Old Jan 27th, 18, 08:19 PM
keith
X-77 keith's Avatar
It is not hard to do. Cutting the cluster for a center fuel gauge or clock is not that hard. As for the tach, you could run your own wires if you desire. I think it has 3 terminals in the rear. Cutting for the tach is not hard either. I cut my new cluster with a air body saw. I have a new fuel gauge and I think a new lens for it that I'm not using. Still in the box. Pm me if you are interested.
X-77 keith
X-77 keith is online now
