Need to test water temp gauge and wiring - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 7th, 18, 12:30 PM Thread Starter
Probationer
Larry
My 69 Camaro console water temp gauge is not reading anything. I grounded the wire from the sender (as recommended in other posts) with the ignition switch in the on position, and the gauge needle does not move at all. I assume that is telling me that the problem is either a bad gauge, or my wiring at the gauge is wrong. I installed a new wiring harness and console with gauges as part of my restoration. Is there an easy way to remove the gauge cluster from the console without removing the whole console? The Tremec TK600 transmission prevents me from getting to the console nuts under the floor pan to remove the console. If there are any other things that I need to check to solve this problem, please let me know. Thank you.
larry williams is offline
post #2 of 4 (permalink) Old Feb 7th, 18, 04:54 PM
Re: Need to test water temp gauge and wiring
Ensure there is some voltage at sender with wire disconnected.
Ensure sender body has a good contact (ground) with engine/intake.
With wire disconnected at sensor, measure sensor terminal to ground; high ohm value, say above 5K ohms = cold reading.
Substitute a 0-5K variable resistor to sensor wire at sensor and with lesser resistance dialed in, gauge should read closer to hot.
Ensure gauge is getting IGN or ACC voltage and the gauge itself has a good ground about its case and terminal.
Name:	Console schematic.jpeg
post #3 of 4 (permalink) Old Feb 15th, 18, 11:23 AM Thread Starter
Probationer
Larry
Thanks for that information. Does anybody know if there is a way to remove the gauge cluster from the console, without removing the entire console from the floor pan?
post #4 of 4 (permalink) Old Feb 16th, 18, 05:46 PM
Donnie
It can be done. You will need to remove the cover for the shifter. Then remove the bolts holding thhe gauge pack into the console. If the front bolts are too tight you may not be able to get it out. It takes some playing around to get the gauge pack out. I only make the front bolts tight and slide the gauge pak in and then tighten the back bolts. It does not move around after that.
Camaro Donnie
1969 RS/SS Black 4 Speed Camaro Coupe
390 Gears with 410 CI small block
Camaro Donnie is offline
