American Autowire Harness install - Team Camaro Tech
 4Likes
post #1 of 21 (permalink) Old Feb 17th, 18, 06:44 AM Thread Starter
Shad
zboss86's Avatar
This should be fun... I'm going to go ahead and do the inside portion of the car. Thought about trying the techflex loom on this go around. They have a ton of variations, I was thinking the F6 flexo or woven. Any thoughts?
Also looking for any pics / articles of where the original wires ran. It's been a while... I can see some of it in the Camaro assembly manual.
www.techflex.com
American Autowire Classic update part # AAW500686
The lowest I could find it was at Autoplicity for $566 if anyone is looking. Summit was $611.
Wiring Harness by zboss86, on Flickr
350sshugger likes this.
My Mistress rebuild...
zboss86 is offline
post #2 of 21 (permalink) Old Feb 17th, 18, 07:31 AM
Matt
Re: American Autowire Harness install
Same exact thing I'm looking at Shad. Only it will take me another year or more to get there. Curious to see how it goes for you.
My Build Thread
350sshugger is online now
post #3 of 21 (permalink) Old Feb 17th, 18, 07:33 AM
Steven
stamatisg1977's Avatar
I have the same kit waiting to go in.
This will be my second go around.
I use harness tape for a factory look
And del city sells zip ties with clips that allow you to secure harness in factory holes.
I got my kit from ground up
$569 with free shipping
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #4 of 21 (permalink) Old Feb 17th, 18, 07:44 AM
Steven
Here is link to the ties
https://m.delcity.net/store/Push-Mou...801509.h_32842
Tremec TKO 600
post #5 of 21 (permalink) Old Feb 17th, 18, 07:46 AM
Steven
And instead of paying rediculous money for the crimping tool
I found that astro pneumatic part #9477
Is perfect for the large and small terminals
Tremec TKO 600
post #6 of 21 (permalink) Old Feb 17th, 18, 07:47 AM Thread Starter
Shad
zboss86's Avatar
You got me beet on the price, I paid another $12 or so on shipping. I'll check with dell on clips...
It really looks pretty simple... My biggest problem is remembering how the wires are routed. The previous harness was butchered and had wire nuts for connectors. So it won't take much to be better than it was...lol
zboss86 is offline
post #7 of 21 (permalink) Old Feb 17th, 18, 09:33 AM
jim
Just wondering, how many of those red cans does it come with? lol
68cvb is offline
post #8 of 21 (permalink) Old Feb 17th, 18, 11:27 AM Thread Starter
Shad
zboss86's Avatar
Not enough....
zboss86 is offline
post #9 of 21 (permalink) Old Feb 17th, 18, 12:53 PM
Steven
I have a brand new alarm system that i integrate into the wiring as i install everything so it looks all factory. No chop shop splices
Tremec TKO 600
post #10 of 21 (permalink) Old Feb 17th, 18, 12:57 PM Thread Starter
Shad
zboss86's Avatar
So I think this is general "path" of the stock wiring... Is this about right? I'm just curious, I'll do it where it hides the best, just curious if this is the path of the stock wiring.
The rear body wiring starts at the fuse block comes down the left kick panel and along the rocker panel.
Wire routing by zboss86, on Flickr
Along the rocker panel, inside of the wheel well through the back seat brace.
Through the back seat brace around the outside of the truck brace and around the outer edge of the trunk.
zboss86 is offline
post #11 of 21 (permalink) Old Feb 17th, 18, 02:06 PM
Steven
top pic:
main harness goes behind those two support struts. dou u see that little piece with the stamp?
one of the main connectors go there.
middle pic:
the beginning is correct but the wires travel up the wheelwell between the inner body and package tray.
bottom pic:
do you see that little tab with the hole just below the trunk hinge support bracket? the wire harness clip goes there.
the AAW harness does not have the factory harness clips that mount the harness to the car in specific places. thats why its good to look for these little 1/4" holes where the wiring harness routes thru and you will have a great idea of where it goes. thats where those push lock zip ties come in handy in the link i provided previously
Tremec TKO 600
post #12 of 21 (permalink) Old Feb 17th, 18, 02:55 PM Thread Starter
Shad
zboss86's Avatar
top pic:
middle pic:
bottom pic:
Ok, I put the main portion behind the two supports
image by zboss86, on Flickr
I think you were saying it goes up the wheel well and through the back seat brace here. I think I blocked it off when I did the mini tub, but I can drill it out.
I believe this is the plug location you where talking about in the last pic.
Yeah, I'll probably get some of those clips from Dell. They'll come in handy.
I also noticed that they don't have the connector that separates the tails light harness at the tail pan. I guess that's less places to have problems.
zboss86 is offline
post #13 of 21 (permalink) Old Feb 17th, 18, 03:02 PM
Steven
yes very good.
on the wheelwell that tiny little open area just to the right of where you are pointing, go through there.
last pic, im talking about that little shark fin shaped tab with the hole in it next to your pinky knuckle
Tremec TKO 600
post #14 of 21 (permalink) Old Feb 17th, 18, 03:05 PM
Steven
true. as far as as a disconnect before the tail panel, you can get a connector and terminals from del city.
hell i have a million of them in weatherpack style. count up how many wires there are and i will hook you up with a connector and terminals
Tremec TKO 600
post #15 of 21 (permalink) Old Feb 20th, 18, 04:54 PM Thread Starter
Shad
zboss86's Avatar
disregard
zboss86 is offline
