1 wire alternator - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 14th, 18, 06:12 PM Thread Starter
Apprentice
john
1 wire alternator
hello upgrading my alternator to a 150 amp powermaster 1 or 3 wire my question is if i use it as a 1 wire will my center console gauge still work showing the amps
Trilexia13567! is offline
post #2 of 6 (permalink) Old Mar 14th, 18, 06:53 PM
scblucam's Avatar
Re: 1 wire alternator
Mine does
68 302 M20 - 85 IROC Z
scblucam is offline
post #3 of 6 (permalink) Old Mar 14th, 18, 08:14 PM
Tom Anderson
When I did it worked very good you can even run the wire to the starter battery post and it comes out clean meaning you don't see the wires
socal_tom is offline
post #4 of 6 (permalink) Old Mar 14th, 18, 08:17 PM
1 wire versus 3 wire:
Catalog
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #5 of 6 (permalink) Old Mar 15th, 18, 11:17 AM
I have some concerns as to why you are going with a 150A alternator ?.
Do you need this extra output due to added accessories or why are you doing this ?.
While swapping in a 150A alternator to replace a 37A-62A original that was on the car is fine, the car if it did only require 35A, the new 150A alternator will provide that as it will monitor things and then only output 35A. If the car then requires 20A of power then the alternator output will be reduced to 20A. The issue one might run into it if the current demands are larger than what the original wiring can handle. If you were to add let's say an additional 60A of current and get this power at the battery and retain the original wire between the stock alternator and the battery, this wire may become overloaded.
While the original ammeter gauge is only setup to read +40A to -40A, if you go above this the gauge will be off scale and then I wonder how long that gauge would last being designed to measure this +40A to -40A if 100A is trying to be read. Thinking out loud here, maybe think about changing out the ammeter for a volt gauge. That would probably give you more information than the ammeter.
SOA-Nova is online now
post #6 of 6 (permalink) Old Mar 15th, 18, 03:01 PM Thread Starter
Apprentice
john
i have duel spal electric fans and electric rs grill headlight kit i called powermaster they said the 150 amp will run at 100 amps and when you need more amps you have it im upgrading the alt wire to 6 gauge
