AAW Bulk head at firewall - Team Camaro Tech
 1Likes
  • 1 Post By Vega
post #1 of 4 (permalink) Old Mar 15th, 18, 01:32 PM Thread Starter
Shad
zboss86's Avatar
I guess I'm being anal on something that doesn't matter. But I don't really care for the screws that stick out of the fire wall. I may have done it wrong... I guess that's the what the factory did, it's been so long I don't recall.
I'm guessing this is the way it's intended to be. Anybody ever just put in riv-nuts instead on the firewall or welded a nut to the back side and used machine screws?
Bulkhead by zboss86, on Flickr
My Mistress rebuild...
zboss86 is offline
post #2 of 4 (permalink) Old Mar 15th, 18, 01:52 PM
Re: AAW Bulk head at firewall
Could you take a small square file and make the firewall holes square to where from the engine side a carriage bolt could be slid through the hole. Once that was done the threads and the rest of the bolt is inside the car and then the underside of the carriage bolts square portion lock into the square hole on the firewall sheet metal. You could then slide the fuse block/bulkhead connector over these two studs and thread on some nuts with lockwashers or use nylon locking nuts to pull the bulkhead seal against the backside of the firewall.
If carriage bolts were used the head could be painted or if made from stainless, have the head polished smooth.
SOA-Nova is offline
post #3 of 4 (permalink) Old Mar 15th, 18, 02:38 PM
Vega$69's Avatar
Cut them off close to the firewall and put a rubber nipple on the exposed threads Use the number 10 screw 2 3/4 inches long with a nut and washer on either side
zboss86 likes this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 4 (permalink) Old Mar 15th, 18, 02:58 PM Thread Starter
Shad
zboss86's Avatar
Been there done that huh...lol I like the rubber nipple idea, that would have never crossed my mind. My main thing other than the screw head looking cheesy is me raking my hand or wires across the pointed screws..
zboss86 is offline
