Wire harness ties and location plus dimmer question - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 15th, 18, 10:41 AM Thread Starter
Rob
robsutt's Avatar
Putting a complete new wiring kit now that all the body work is done. When I went to install the fuse box and main dash harness I noticed the clips that hold the harness to underside of the top dash are gone. Just have the 1 main one near steering column. Have been searching sites and canít seem to find anything. Any suggestion on where to get them and the location for them? Looks like assembly manual shows 2 of them near the defrost vents.
Also does anyone have a pic of the dimmer switch area without carpet? After the body work I only have one screw hole for it. Lol. Want to drill and mount it at the correct angle and distance.
Thanks.
1968 RS Conv - My Build Thread:
robsutt is offline
post #2 of 4 (permalink) Old Apr 15th, 18, 07:04 PM
Larry
Re: Wire harness ties and location plus dimmer question
I don't believe I have seen these straps reproduced. You could cut a strip of sheet metal, dip it in some Plasti-Dip and plug weld it in place.
Here is a photo from my last build that has the dimmer in view.
Current Project:
69 Z/28 Resto-Mod
Next In Line:
83 Z28 Restoration
69-er is offline
post #3 of 4 (permalink) Old Apr 15th, 18, 07:44 PM
Steven
stamatisg1977's Avatar
I believe ricks sells the straps
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #4 of 4 (permalink) Old Apr 15th, 18, 10:24 PM Thread Starter
Rob
robsutt's Avatar
Almost parallel to the floor... assembly manual seems to have it up a bit on the left side. Seems both will work. Thanks.
robsutt is offline
